Tadpole's Avatar
Bruce's tip for webers
Hi everyone,
Was doing some follow up research on weber carbs and came across someone mentioining a tip that Bruce Anderson suggested to do on the carbs. I think it had to do with the float bowls. Does anyone know what it was or the link to find it? Thanks for any help..
Mike
'75 911S
'76 911S
Old 11-30-2008, 04:36 PM
Mike, I think you might be referring to increasing the float level height of the front two float bowls as they feed two throats(whereas the rear bowls only feed the rear throats)by 1mm or so as this helps them maintain adequate level under high demand.
Keith
72 911 2.4T W/2.2 S pistons,webers,SSI.
66 912 Gulf Blue with Red Interior original.
Old 11-30-2008, 05:18 PM
BURN-BROS's Avatar
I think this is what you are looking for PAGE 150
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-30-2008, 05:22 PM
Tadpole's Avatar
Thanks alot. You guys rock
Mike
'75 911S
'76 911S
Old 11-30-2008, 06:18 PM
