mnmasotto's Avatar
Need help with grease gun
I bought the grease gun offered here at PP:
http://www.pelicanparts.com/catalog/ShopCart/TOOL/POR_TOOL_CAT575_pg3.htm
I like the gun, but the tip is almost impossible to remove the grease nozzle from the zerk fitting. I have already broke one of my zerk fittings on my ER polybronze bushings. I have looked carefully at the unit. The instructions are sparse. It says nothing about attaching and releasing the gun/nozzle to a grease fitting. I do not see a spring action lever or button to release the zerk fitting.
Am I doing something wrong? Does anyone make a quick release nozzle to make the on/off step much easier?
Help!!!!
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 11-30-2008, 11:34 PM
3.2 CAB's Avatar
The grease guns that I have had and still have look pretty much like that one shown, except I always change out the hard pipe, and install one of the flex hose kits. The zerk tightness can be adjusted on some by rotating the shroud at the tip. Think of it sort of like a drill chuck, turn it one way it tightens up, turn it the other way it loosens the grip on the zerk fittings. Have you tried to adjust yours? Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-01-2008, 06:04 AM
it's early, but i can't think of any zerks on your car.
206 637 4071
Old 12-01-2008, 06:28 AM
Monkey Butt Forespin
84_Carrera's Avatar
Yeah I need to get a flex-hose / 90 degree end on my grease gun too... the way I installed my Poly-Bronzes, the pass / rear is near impossible to get to with my stubby gun.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 12-01-2008, 06:49 AM
Zeke's Avatar
It is early JW, but he has ER polybronze. Surprised you didn't catch that.
Mark, the tip should be somewhat adjustable, but some just take a big yank to remove. One thing that can happen is that the grease itself is creating a connection. It can't be a vacuum, because fluids don't behave that way. But think that way anyway and pull the gun off while you're applying pressure to the pump arm.
Old 12-01-2008, 06:51 AM
mnmasotto's Avatar
I have the flexible hose installed. Does not help much. The amount of force needed to remove the nozzle from the grease fitting is unbelievable. I checked the tip. It is not adjustable.
2007 997 GT3 - SOLD
Old 12-01-2008, 06:58 AM
Zeke's Avatar
Send it back. They should work better than that.
Old 12-01-2008, 08:59 AM
Friend of Warren
Could be the zerk is overly large. The ones that used to come, and may still do, on the polybronze bushings were an odd size.
Kurt V
Old 12-01-2008, 09:04 AM
I've always have a bit a difficulty with just one of the rear ER zerks (mounted at the same angle on the other side). I've got an adjustable regular tip and also one of the 90 degree slide on type attached to a flexible hose and they don't really help much. 7 are a snap, but that one has always been a PITA.
Old 12-01-2008, 09:24 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Zerk fittings come in various sizes. The business end of the grease gun should fit in snug with a gentle 'click'. If not, its the wrong size. Same concept as an air line fitting.
Michael D. Holloway
https://5thorderindustry.com/
Old 12-01-2008, 12:05 PM
Go to NAPA or one of the others and get a replacement tip, most good brands are adjustable I just checked mine.
LM
83 SC
Old 12-01-2008, 12:31 PM
