e p slick's Avatar
Torque wrench
Aw shucks. That was just a pre-emptive rant. The Bastard car was a few years ago - Wintertime project. Sold it for an obscene amount of money to some cat in Kuala Lumpur and now have a "real" 930 (My third). The new one has K27 HF, 964 cams, Kokeln, Leask adjustable WUR, Carillo rods, MSD etc. EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 12-03-2008, 12:55 PM
dshepp806's Avatar
Originally Posted by hcoles View Post
other posts here or other places recommend not to use/trust the bottom 25% of the torque wrench range... I guess this would be on a click type...
Damned relevant point there.
DO check your manufacturer's specs, particularly at the "rails",..you'll quickly see where price differentials lurk. The +/- is more sloppy at the endpoints.
I used the Kohl's variety, 100 ft lb'r for about 6 months for my wheel lugs then realized the error margin (yes,..let's pick a bit of flysheeit out of the pepper...). Now (and smartly so) I use a 150 - 200 ft lb'r so that she lives in the mid (and more accurate) region of her rating.....as Hcoles speaks of this bottom end, so goes the top,..maybe a bit less...just check your specs and you'll know what you have to work with.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-03-2008, 02:59 PM
