AutoBahned
what else weighs 40 lbs. or more?
Max Sluiter
Sunroof
Air Conditioning System some exhausts with multi-catalytic converters and a big muffler
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Stock seats
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
yep, rear seats, rear shelf, speakers, stock front seats and belt, console,
86' 911 coupe |
Those big fat rubber bumper guard add-on things hanging out off the rear! I've gotta get rid of those.
Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Work in Progress
I don't have any verified #'s but:
1. The pair of trailing arms have to be pushing 40lbs. Maybe I am wrong on that one becuase I always pick them up with the bearings, wheel hub, and rotor still attached. They always feel heavy. 2. The doors with the windows included have to weigh darn close to 40 lbs each. At least in an SC with the added impact resistance and power windows. As a naked shell I doubt they weigh 40 lbs individually though.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Sultan of Sawzall
The African Swallow in the back seat (very laden, of course).
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Eact bumper on an impact bumper car.
A G50 over a 915. A mag trans and motor case compared to aluminum ones. Front steel hood with hinges and shocks. The galvanizing and rust treatment on the newer body shells. Maybe the rear iron disk brake hats, parking brake parts, dust shield, and cast iron calipers. Steel front fenders with lights. |
Stahlwerks.com
SC electric window doors are about 70 pounds each, you can take out almost half of that....
light weight door project
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
The easiest thing to lighten would be the driver!
Too many cars, not enough moolah... |
Although it does not weigh forty pounds, a full windshield washer tank anchored high up inside the driver's side front fender on a Carrera 3.2 is heavy. I don't have my manual handy, but it must weigh at least 8-10 pounds.
Mike |
Work in Progress
Yeah that thing is huge. I am working on my front bumper and just took the washer tank out. I am thinking of keeping it out and putting a bag in the front trunk like what was used on 60's mustangs. Wonder if that is possible?
At the track = great day
I just pulled the washer fluid tank and left it out.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
Rich76-911:
I simply deleted the tank, pump, and all associated lines. It all happened the same weekend I removed my complete A/C, interior, spare, jack, battery, "badd a$$ stereo system", etc... I appreciate air-cooled 911's that are bone stock and in near showroom condition. Almost any 25+ year old "time warp" car is cool to look at. But, when it comes to actual driving, a Carrera 3.2 or any other impact bumper 911 stripped of nearly 400 lbs is vastly more entertaining to drive than in stock trim. Mike |
Just an aside, but did anyone else notice the illustration shows an oil tank with 4 quarts of oil? Keep that up and you'll be able to pull out the 420lbs. of the engine--for a rebuild.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
AutoBahned
This is an early car.
I guess I don't mind people noting bumper car stuff - but let's try to keep it to 40 lb. or more of concentrated wt. The tank does not have a huge amt. of oil in it when the car is running. If you think 4 Qts. is not a good estimate, post your estimate and how it was arrived at. I usually hear people give estimates of 36 to 38 lbs. for the sunroof - I might color it in tho - along with the seats (26 lbs. each - Recaro SE). It is not at all easy to make the driver lighter... |
The stock muffler is quite heavy. Maybe not 40lbs, but there is savings to be had in an important area to reduce weight.
AutoBahned
posted motor wt. is 3.2L carbed motor as modified - Monty muffler
Air Medal or two
Rockers and rubber and rear seat back delete will get ya a big chunk , 30 lbs if I remeber ...right
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
i wouldn't mind doing that either
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
