Weber rebuild kit
Does anyone know where I can find a weber rebuild kit for my 69t? Pelican doesnt seem to have them and I check automotion too. Actually, I just need one set of diaphrams for one side which is leaking badly.. I just need to start and run the motor for a bit during the rebuild... Almost started a fire today as it leaks down onto my header pipes.. probably not good to let it get hot Im guessing.
JP '76 911s Ice Green Metallic bone stock |
oops...
I was just going to buy some also and do the carbs as a winter project. interesting to see if anyone knows of kits available? brant
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
JP,
Call me during busines hours as I might be able to help.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have a couple extra kits if Steve can't help you out...
Tony Proasi 1969S 1957 VW Pickup |
Get a hold of Richard at PMO. If you are unable to get in touch with him, EBS Racing will source this stuff from him as well. I just went through this about a month ago
It is funny , I used to be able to get these from the local parts store .
No left turn un stoned |
I have a source as well, but won't step on any toes unless all else fails. Regardless, the items will cost pretty much the same no matter where they come from. That is AFAIK.
Pierce Manifolds, Gilroy, California.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I spoke to Steve.. wow, nice and knowledgeable guy! He had a full kit if anyone needs one. I was able to get a gasket kit from Pierce Manifolds. They have 8 in stock right now.
Thanks for all the help!!
