For all of you early 911 hot rods, what is the best motor-chassis combo?
I currently have a 3.0 in a 72, but couldn't help thinking about a 3.2 or a 3.6. With the bigger engines weighing more, what do you all think about the best engine for the early 911s? I know jumping to a 3.6 will make a HUGE difference, but will a 3.2 make a very noticeable difference over a 3.0? Is the 3.2 worth the extra dough? will the extra weight of the 3.6 take away some of the go-cart feeling of the early cars?
Old 12-05-2008, 10:45 PM
Administrator
Jack Olsen's Avatar
The numbers you usually see on the later engines are misleading. With a 3.6, for example, you immediately ditch about 100 pounds when you get rid of the dual mass flywheel, stock exhaust, heater blower and power steering pump for a swap into an earlier car.
Bill Verburg listed some weights that were more apples-to-apples than the ones you usually see for 'fully dressed' engines.
My Carrera 3.0 weighed ~#405 with cis/ssi no muffler and sachs clutch & p/p.
The M64 3.6 that replaced it weighed ~425 with motronic/ssi no muffler, centerforce clutch & p/p sans ac.
A 2.7 with cis/ssi no nmuffler, sachs clutch & p/p was ~390#
A 3.2 with Motronic/oem exhaust with muffler,ac, stock clutch & p/p weighed ~440#
All were weighed with electronic corner balance scales.
I'm not sure, but I would guess that the SC 3.0 is slightly heavier than the Carrera 3 version Bill weighed.
It's probably safe to say that the 3.0, 3.2 and 3.6 are all within 40 pounds or so of each other when used in the same car.
Old 12-06-2008, 12:46 AM
Non Compos Mentis
I've only driven mine, with a 3.2, so I can't give you a detailed comparison. What makes my car such a hoot to drive is the 7:31 ring & pinion, and shaving the weight down to 2200 pounds.
How do you use your car? My combo is a blast on the autocross course, but wouldn't make a comfy daily driver.
Old 12-06-2008, 05:19 AM
Bill Verburg's Avatar
the weights from lightest to heaviest are 2.7, 3.0, 3.2, 3.6 but the range from lighteset to heaviest when similarlay equipped isn't that much @ ~ 40# and no it won't take away for the go cart feel irt will enhance it.
ancillary equipment makes a big difference too, exhaust, pressure plate, intakes etc all vary widely in weight
The aluminum blocks are going to be much more stable than the mg at the cost of a few #s, the torque of the bigger engines is a wonderful thing especially on a street or dual purpose car.
Bill Verburg
Old 12-06-2008, 06:13 AM
Sports Purpose 911 Driver
mjshira's Avatar
I agree with Bill which is why I have an 8:31 euro gear box. I have had a 3.2 early car and now a 993 early car. The later is a whole different level of car. In fact more car than my driving skills but that doesn't stop me from having fun ;-)
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 12-06-2008, 07:42 AM
AutoBahned
RWebb's Avatar
I also went with an Al motor, despite already having a good condition Mg case 2.7L. IIRC Al adds 25-40 lbs - would have to look that up. But your SC motor is already Al.
And, yes, it all depends on the induction and exhaust system.
Also - the 3.6 motors already have twin-plugging, so you save $$ there, tho yo u pay more upfront.
If you have stock CIS on your motor then a DME 3.2L will give a bump up. If you have carbs now then you are pretty close already to what you can do with a 3.2L on carbs.
What are emissions regs where you are??
Old 12-06-2008, 11:10 AM
user & abuser
i've had the 2.7L mg case with cis as well as a 3.5L based on a Al 930 case w/ webers, i likely changed to much to just talk about the weight difference, but it feels similar when off-throttle..
vini vidi vici
Old 12-06-2008, 11:27 AM
no smog since it is a 72. I forgot to mention I have a 7:31 915 with stock CIS and stock body. I have been keeping my eyes out for a 3.2 or 3.6. There are two 3.2s available locally at present, don't know if it is worth my while or if I should hold out for a 3.6.
Old 12-06-2008, 02:18 PM
dial 911's Avatar
hold out and get a 3.6!
Old 12-06-2008, 03:01 PM
AutoBahned
RWebb's Avatar
if you now have a1 carb'd 3L with the right cams, then I'd wa1it for 1 3.6L motor to become available.
3 to 3.2 with same intake/cams/exhaust is just not that big of a step...
Old 12-06-2008, 06:12 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Considering you can easily get 275HP out of a vario 3.6 why in the world would you be concerned about a few pounds? My car weighs 2500, runs a stock 3.0 (180HP), and is a blast on the track. Sheesh...
Gary R.
Old 12-06-2008, 06:20 PM
Wer bremst verliert
JohnJL's Avatar
I've got a hot 3.0 putting out ~240hp in a 1971 targa and I can tell you its everything you could possibly want on the street. Its also a handful on the track and in tarmac rallies and thats with coil-overs, SSIs and webers.
Whats the output put of the motor now? You may find it most cost-effective to squeeze some more performance out/lightness into the car as-is rather than major surgery.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-06-2008, 06:54 PM
