Quick question - Remove windshield to get the dash out?
I have some cracks in my 71T dash and I looking to do a DIY job to repair.
Does the windshield need to be removed to get it out? Thanks in advance. Andy |
AutoBahned
yup
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
si
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
AutoBahned
I'll see your si, and raise you a oui.
What? No ja?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
AutoBahned
odd, isn't it....
no ja, da
Slumlord
Not an easy job. Why are you doing it, crack repair?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
yes, I would like to repair a few cracks on the top.
The car is a track car, so I am not overly concerned. I just do not want to go through removing the windshield. I read up on your experience and was thinking of trying a variation of it. Andy |
![]() The only dashboard that can be removed without taking out the windshield that I know of is the '65-'66 with "buttons". The buttons are plastic covers which stick on the face of the mounting screws.
'65 911 Coupe (301278) |
Evil Genius
Okay, so my question is......once the windshield is out, (my 1982 911SC) then my bentley manual states to take the 5 scews along the forward edge of the dash by the defrosters out, yup, did that, then Bentley says "take 7 nuts off the back side to remove the dash." (they don't show diagram or arrows/pictures"
Do you have to gut all your henting/ventilation gear to access these 7 nuts? Are they on the "Bottom side, of the flat mounted top dash"? or more on the vertical fire wall where the dash gauges are mounted? I'm lost at this step, can't find the nuts, and its driving me nuts. thanks for any tips.
Life is a big ocean to swim in. Wag more, bark less.
I'm guessing that its referencing the nuts that you access from the trunk area. I can't recall 7 of them though. One on each corner of the dash, one each on either side of the the dash vents and I think two in the area in between the vent and passenger nuts. Must be one more between the drivers side of the dash vent and the guage pod.
Some are a little fiddly to get at but not too bad. Reach towards the dash from the trunk and feel around. Start with the ones in the extreme drivers and passenger side corners to get an idea of where they are located.
Rob 1979 911 SC Targa 1982 928 Weissach Edition |
Brian
'82 SC Targa '83 SC Cabriolet |
Evil Genius
Well if I can get it out, I'll have a mint black dash cover for sale soon........car is dead and getting parted out.....thanks Rob and Brian for your help.......
give me first shot please
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Insert Tag Line HERE.....
OK what? Ive pulled many dash covers off without pulling the windshield on 72 and up cars.
(dont know about earlier ones because i personally have not done one.) |
AutoBahned
dash covers? i.e. aftermarket things
or dashes? |
Dashes. Why would you have to remove the windshield? When i thought deeper about it, some of the ones I did already had the windshield out, but some didnt.
My 66 without buttons can be removed with windshield in place. Not sure what to tell you!
