Slumlord
Porsche_monkey's Avatar
Originally Posted by dfink View Post
I'm guessing at somewhere around 11K to 12K.....
Once............
Me too. Stuck throttle. pushed the clutch before I turned the key.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 12-10-2008, 06:59 AM
Bill Verburg posted this information in the past:
oem limiter specs
930/03 & 13 6800+/-200
930/04 & 05 & 15 & 06 6700+300
930/07 & 08 & 16 & 17 6500+200
Robert, if your cabriolet has its stock 930/16 engine, your rev limiter (the black box under the far left of the dash) should have cut off the fuel pump at 6,500-6,700 RPM.
Brian (who has never approached a rev limiter cutoff)
'82 SC Targa
'83 SC Cabriolet
Old 12-10-2008, 07:24 AM
Super Moderator
cstreit's Avatar
I ran my stock 3.0L up to about 7800 RPM once.
Now it's built to 8.2k and I run it to 7200.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-10-2008, 07:27 AM
That one valve does look a little out of skew.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 12-10-2008, 07:32 AM
Student of the obvious
LeeH's Avatar
9K or so on a missed shift. I won't post the pick of the six bent exhaust valves... very similar to the pic above, but thankfully no other damage.
Lee
Old 12-10-2008, 07:37 AM
AZ1977911's Avatar
About 3 times (or did you mean RPMs instead of Dollars)...
Old 12-10-2008, 07:49 AM
LeeH's Avatar
Originally Posted by cstreit View Post
What exactly am I looking at in this photo?
Lee
Old 12-10-2008, 12:44 PM
abit off center
cgarr's Avatar
Looks like a bent exhaust valve that took out the guide. Those are really bent or my astigmatism is really bad!
______________________
Craig
G2Performance
Old 12-10-2008, 12:46 PM
Back when dinosaurs trod the earth, I was able to talk a buddy into swapping P-cars for the drive from Mobile to Talledega. He "got" to sheppard my '57 1600 normal speedster, and I was forced to drive his '56ish 1500 Carrera with four cams, two mags, dual spark plugs (absolutely unreachable)no sound deadening, plastic windows with leather straps for regulators.
Redline as I recall was just over 8,000, something I never reached due to the NOISE, the aggravating part was the GREEN line of 4,000. Drive under 4 for ANY time, and you found yourself on the side of the road, employing a cable ratchet extension device to attempt to pull all 8 plugs. In first, the Tunnel traffic was moving at less than 3,000. He was screaming "Blip it!!!" As I coasted to a stop at the bottom of Bankhead tunnel.
I wonder if it would seem as torrid today...seems like the Speedster had 60hp and the Carrera 120...about half what a really healthy VW will do.
Old 12-10-2008, 02:44 PM
pwd72s's Avatar
Factory redline on an early S is 7300...
Old 12-10-2008, 05:44 PM
1968 2.0s
It is indeed and I`ve been up to the limiter a few times...... but looking at these photos, perhaps not so often from now on
Mike.
1968 Super. 1959 Super.
http://tinyurl.com/pbvfl5w
Will this learning curve ever level out ?
Old 12-10-2008, 10:15 PM
petevb's Avatar
The redline on a GT3 is 8400...
Old 12-10-2008, 10:36 PM
