Manassas, VA
lucittm's Avatar
Has Anyone Fixed Their Heated Seats?
The heated seats in my car have never worked since I have owned the car for the past two years. I heard they were prone to being left on, since there is no indication light to let you know and the switch is in a place where you cannot see it from the driver's seat.
These cold mornings, I sure would like to warm my tush. I have heated seats in my truck and have become quite attached to the warmth.
Is there an economical way to make these seats work? I assume the heating element is fried since the fuse is good. Could a GM seat element be used?
I would like to know if anyone has made their heated seats work again. Or, how hard is it to get to the OE element and insert a replacement?
Also, any comments about installing an LED in the dash to show when the seats are "on"?
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-14-2008, 06:14 PM
old man neri's Avatar
911s have heated seats? Wow.
I notice you have a 964, you may wish to ask the 964 board about this problem.
Old 12-14-2008, 06:55 PM
3.4 Bigger is better
88-diamondblue's Avatar
Check out this link. I was looking at these for a Rav 4 that we have. Supposed to be an OEM supplier for many autos. http://www.heatedseatkits.com
Should be pretty easy to install since all the wiring and switches are already there.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 12-14-2008, 07:08 PM
3.2 CAB's Avatar
I know that BMW has OE replacement, seat heating elements available, but I don't know if Porsche offers the OE heating repair parts. I have not had to repair my sport seats heaters, yet. I think it would be fairly easy to mount a "seat heating light" Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-14-2008, 11:52 PM
mark 74 carrera's Avatar
As part of a restoration, I wanted to add heated seats for my wife. On the internet, I researched aftermarket heating elements that were easily cut into the shape of the 911's seats. They were relatively inexpensive and were installed as a part of the seat's recovering. The wiring harness was provided and my mechanic did the electrical set up.
The advice might not apply to you if you are trying to use OEM parts to fix your existing seats. If your car is old enough and you're not worried about any warrantees you may want to consider aftermarket.
Mark
Mark Isaak
1974 Carrera Targa - Light Yellow, Being driven
1974 Carrera Targa - Orange, Being restored
1974 Carrera Targa - Lime Green, Being pampered
2017 Macan
Old 12-15-2008, 02:52 AM
