crashr's Avatar
Gas Evaporator System Questions
Hi Folks,
I have done a lot of searching on the topic but can't find the answers I need.
First of all my car is a 1975 911 however I have a 3.2 engine in it.
The last few years I have noticed that I am getting a fuel smell in the cabin after the car sits overnight. I did some searching and most posts point to the fuel evaporator system. I started checking my hoses and noticed that many of them were fraid, dried out, and cracking. I would like to first replace these hoses but have no idea what kind of hose to replace them with. I couldn't find the braided hoses on Pelican. Can someone please recommend a type of hose that should be used?
Secondly, when the 3.2 engine was put in the car the charcoal box lines were never hooked up again. I am hoping that someone can tell me where on a 3.2 I could hook up these lines, keeping in mind that my charcoal box is in the rear of the car. I believe one of the small braided lines (which is in really rough shape) runs from the front expansion tank to the rear of the car. Can I just replace this hose and pull a new one through the car? The other two lines that go to the charcoal box appear to be larger hoses (however I don't have them). From diagrams it looks as though I should connect one to the back of the airbox, however for the other one I have no idea where to connect the pressurized line to the engine.
1975 Widebody 911 3.2 Euro
Old 04-05-2010, 06:58 AM
HarryD's Avatar
Dennis,
You need to reconnect the lines. This drawing shold help you with the routing:
Originally Posted by Grady Clay View Post
The evaporative emissions system is actually very useful
and worthwhile to keep in working condition. First and
very important, your 911 doesn’t constantly smell of
gasoline. If you are missing the charcoal canister, it
is common to many German cars of the era. Just tape
over the VW logo.
Here is the diagram for ’69-‘73:
With CIS the system was simplified somewhat.
© Dr. Ing. h.c. F. Porsche A.G.
1) Fuel tank
2) Expansion chamber [LF fender]
3) Activated charcoal filter [a reservoir for the fuel vapors]
4) Cooling fan shroud with hose connector [source of air]
5) Hose from cooling fan to activated charcoal filter [supplies
air to the charcoal]
6) Hose from activated charcoal filter to air filter [carries
the fuel vapors to the engine to be burned]
7) Engine air filter
8) Return hose connecting the fuel tank to the expansion
chamber [this clear (now brown) hose typically shrinks
and comes off the fittings causing gas fumes in the trunk
and cockpit]
It is worth having all this stuff because some day you (or a
future caretaker) just might be required to have it functional.
Best,
Grady
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-05-2010, 07:36 AM
crashr's Avatar
Hi Harry,
Yes I saw this diagram in a couple different posts that I searched. I guess one of my questions above was, On a 3.2 Engine, does #5 Line in your diagram above exist on the cooling shroud." I am not aware of where this is, can you comment?
I am also interested in what type of hose is suitable for replacement and where can i find it. I think I saw in a post that standard rubber hose is not good for this application.
Old 04-05-2010, 09:29 AM
HarryD's Avatar
Dennis,
I am not very "expert" on the newer 911's. Hopefully someone who knows will step up.
I would think any standard fuel/vacuum hose would be ok. Check for gasoline fume compatibilty.
Harry
2020 MB E350 4Matic
Old 04-05-2010, 09:52 AM
AutoBahned
RWebb's Avatar
the hose must be rated for fuel or fuel vapor - ordinary PVC hose is not good
so, go to a hose place not a hardware store
as a fellow 1973.5 911 formerly T owner, I also dunno about your new car...
Old 04-05-2010, 11:33 AM
crashr's Avatar
Hi RWebb, I was hoping you would post as you seem to have some good knowledge in this space from what I could tell in my search.
I will check out a hose place this week to see what they have.
Any comment on how best to route the 2.7 Charcoal box, to a 3.2 engine?
Old 04-05-2010, 11:47 AM
AutoBahned
RWebb's Avatar
on my car, the canister is up front and the lines run inside the tunnel (that would be a lot of effort to add them post hoc)
on the '75 I used to have, the canister was in the upper RH side of the engine comp. but I don't recall how the lines to the front were run
if the existing line in the tunnel is not fastened, then you could use it to pull the new one
BTW - the trunk to tunnel connection IIRC goes thru the cabin above the pedal cluster
Good Luck
Old 04-05-2010, 01:08 PM
Cooper911SC's Avatar
Hi Dennis,
Pelican sells the cloth braided German fuel and breather line by the meter. Sorry about huge link...I just searched on the site. You might call if you dont see your size listed as I'm sure they can get it from their supplier. You could also try local vintage VW suppliers/shops in your area. I have also purchased this style hose from them.
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
I used some of this line for the vacuum lines on my SC. It is ok for fuel.
You will need to verify the I.D. and lengths you need of each size. My memory is that the larger size is somewhere around 10mmID and 13MM OD.
Good luck with your project.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 04-05-2010, 03:07 PM
cary's Avatar
Ditto on Cooper's input.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 04-06-2010, 04:47 AM
crashr's Avatar
I have a question about the above picture showing the venting system. Where on a 3.2 can I find a line that will provide air to the charcoal box. On the 2.7 it came from the shroud but that hole doesn't seem to exist on a 3.2.
Thanks,
Dennis
Old 06-07-2010, 08:15 AM
This is pretty complex for a guy from Montana! I have a '73 911T with a '76 2.7 in it; the charcoal cannister is up front next to the battery. I also have fuel smells in the cockpit. I wonder what the problem could be: a) no "fresh" air from the engine fan; b) the cannister is 34 years old and needs to be replaced; c) ???
Sorry to step on your post, but seems related to the overall problem.
Tom
Old 06-07-2010, 10:31 AM
AutoBahned
RWebb's Avatar
canister is good until it bursts unless you got liquid fuel in it
replace all your hoses in the trunk & check tanks under cowl & fender for cracks before doing anything else
do a search - you cannot use regular PVC hose from a hardware store
Old 06-07-2010, 11:47 AM
HarryD's Avatar
Tom
Tom:
For your car, Grady Clay posted this which should help you to see how it "should be".
over the VW logo.
Here is the diagram for ’69-‘73: “
1) Expansion chamber [the black box under the cowl
on the driver’s side]
2) Vent chamber [behind the LF headlight]
3) Activated charcoal container
4) Engine fan shroud
5) Pressure line from fan to activated charcoal container
6) Purging line from charcoal container to engine air cleaner
Note the 13 connections around #1 and the fuel tank. This
clear (now brown) hose typically shrinks and comes off the
fittings causing gas fumes in the trunk and cockpit
Here are the locations in the 911.
1) Fuel tank
and cockpit]
This diagram shows CIS but the system is the simular for
MFI and carburetors from ’69 as above. The two tubes
in the tunnel are #5 and #6.
Best,
Grady
Harry
2020 MB E350 4Matic
Old 06-07-2010, 12:41 PM
crashr's Avatar
Can someone comment on where a 3.2 charcoal box gets its fresh air supply from?
Old 06-07-2010, 01:40 PM
Senior Advisor
James Brown's Avatar
look in the PET for your 3.2 (like a 90 Carrera) to find what hose to hook up to. Hard to find the CIS connections on you 3.2. You will have to marry both systems together to make it work but it's not that hard, just need the correct source of vacuum and your in business.
08 Cayenne Turbo
Old 06-07-2010, 01:59 PM
crashr's Avatar
I have done that. Unfortunately for all the 3.2's from 86-89, PET only shows the carbon canistor which has 3 inlets. One must come from the trunk, the other goes to the back of the airbox, its the 3rd which provides air into the carbon canister that I am curious about.
Old 06-07-2010, 02:08 PM
Senior Advisor
I'm thinking one is a air inlet, one from the airbox, and one from the tank. Not sure which is which, sorry.
08 Cayenne Turbo
Old 06-07-2010, 02:22 PM
crashr's Avatar
Hi James,
I agree one is the air inlet, the question is, where does the air inlet come from?
Old 06-07-2010, 02:25 PM
Senior Advisor
Oh, its just open to the atmosphere.
08 Cayenne Turbo
Old 06-07-2010, 02:29 PM
crashr's Avatar
Really? PET shows a hose going to it. Where does this hose lead to that just opens to the atmosphere?
Old 06-07-2010, 02:35 PM
