Fan housing magnesium or aluminum?
Is the 80 SC fan housing magnesium or aluminum? I have a few cracks and I like them welded if possible.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I believe magnesium but the welder should be able to tell with a quick try. If it's mag. and he uses aluminum rod it doesn't take. I think that's what the guy did when he welded mine.
O2 In Sully We Believe |
So can he weld magnesium, or does it just burn?
up-fixing der car(ma)
some people can weld magnesium, which is what it is made from
(it's not going to catch fire)
Scott Kinder kindersport @ gmail.com |
Not sure what you mean by burn. I'm pretty sure it's mag. and I'm sure someone like Milt will chime in. I'm just saying if it's not the same the rod material will just like drop off. I just had mine done last winter, (took it apart to polish).
Ok, the guy I went to had both kinds of rods. He did some rough welds. I took the housing home filed and shaped them.
Max Sluiter
It is Magnesium, which will rapidly exothermically oxidize (burn) if welded without proper inert gas shielding. Magnesium parts are cast in an atmosphere of Nitrogen or other inert gas.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Ain't this board grand. Great info.
The part is too large to burn; it acts like a heat sink to some extent. The whole part will not get hot enough to ignite (not enough total activation energy to begin the exothermic reaction, in chemistry-speak). Therefore, it is possible to weld it.
If you put vinigar on Magnesium, it will foam a little and turn milky white. This will not happen to aluminum.
Rob |
'82 SC Targa '83 SC Cabriolet |
I just got an aluminum one from vertex and avoided all the trouble all together.
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
Not for $450. I hope to get it welded for less than $100.
Magnesium powder will burn bright white when ignited. It was used as flash powder in the early days of fotography. It's also used in fireworks and flares.
As a solid it is much harder to ignitebut not impossible. Once ignited it will burn even in nitrogen. Sounds nasty to me.....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Max Sluiter
Only the Germans would make engine parts like crank cases, fans, cam housings, transaxle housings, etc. out of such a metal. Right near combusting gasoline, hot exhaust, fuel, air, electricity...
But it is lighter and therefore faster.
THE IRONMAN
It's magnesium...and it's weldable. It's the answer you look at.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
they are mag and I have welded a few of them. Most welders are not real familer with mag though so be careful when chossing. I teach mag in class so I get my fair share of welding that nasty smelling mag
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
