Cattler's Avatar
Porsche Crest Confirm procedure--old post on cab top alignment
I found this post after a thorough search of the site--its from 2003 and about a 993 roof alignment. Most of this seems similar to the hardware in the rear of my car, but want to know if anyone's tried this on their cab, what to look out for, etc. This seems to address getting the top to fully lower (which mine will do)...I need to figure out how to pull the passenger's side forward a little bit.
I have a lot of wind noise and a noticeable gap (~1/8 to 1/4") on the passenger's side, where the roof meets the windshield frame. Seems like a (relatively) simple procedure to follow, but I know the cab tops are a PITA to deal with.
Thanks,
From: http://forums.pelicanparts/com/showthread.php?t=136131
The first thing he has to do is get the tension off of the cab top.
Do this by undoing the 6mm allen bolts on the top of the transmission arm - this will disconnect the cab frame from the transmissions. Do not loosen the 19mm bolt in the center of the transmission.
With no tension on the top, the top should drop into the guides on the windshield frame. Use the power latching to lock the top closed.
Next. Remove the backpad and disconnect the drive cables from the cab top motors.
Now it is time to remove the transmissions and realign them. Unbolt them from the side panels of the car - 3 X 10mm bolts with spacers behind them.
(You do the following to both transmissions)
On the back side of the transmission, you will see a black plastic plate and a silver plate where the cable connects. Remove the screws that secure the silver plate. This will disconnect the drive cable from the transmission. Clean and regrease the gears and the cable. Set aside for the moment.
Check the transmission arm for free movement The arm should move through 360 degrees of rotation without binding or catching anywhere. If it binds anywhere, the transmission is damaged beyond repair and must be replaced.
(This next part is optional)
Assuming the transmission moves freely, loosen the 19mm bolt in the center of the transmission and remove the arm and the shims that are behind it. Note the orientation of the arm as it relates to the gear
The "Half gear" and center hub should pop out of the transmission housing at this point.
Clean and grease the center hub.
Replace center hub and "Half gear", replace the shims and arm, tighten canter bolt (blue loctite optional)
(End optional procedure)
Now for the alignment (this also applies if you are replacing the transmission): On the center of the transmission arm, you will see a raised nub, about 3/4 of an inch long. On the transmission housing, you will see a notch. On a replacement transmission, they will be aligned already - Otherwise, line the nub up with the notch.
Reinstall the gear drive on the back of the transmission
The transmission is now at factory defualt for a closed and locked top.
Reinstall the transmission on the side panel of the car - leave the bolts loose for now.
Repeat the above procedure for the other transmission.
Now that both transmissions are installed, but still loose - reattach the arm on the transmission to the cab top frame. With the transmissions loose, you can move it around a bit to "find" its natural position.
Once the transmissions are reattached, tighten the bolts holding the transmissions to the car.
Reconnect the cables and test.
If you are still a bit off:
Below the transmission, there is what looks like a big butterfly nut secured with two 17mm bolts, one on each "wing".
Loosen the bolts and slide the cab frame forward or back as necessary.
Do not touch the nuts below the butterfly.
Retighten.
If you are STILL off. Behind the small zippers on either side of the cab top, you will see the main supports for the cab top. the support is held in with 6mm socket head cap screws. Take a 6mm allen wrench and loosen the screws and slide the frame a bit more forward or back as necessary.
Still off? Seek professional assistance.
AFJuvat
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 12-16-2008, 06:10 PM
Cattler's Avatar
bump
Old 12-19-2008, 07:09 PM
