pm sent to you Tony...
Thx again! Bob |
My father builds custom cabinetry, so mine will end up in a very nice box at some point.
If others are interested, and if Tony does not offer something, I will take photos of whatever my father designs and will ask him to work up some quotes and options. This will of course have to be after the tool arrives so he can take measurements and design the box. By the way, what is the VW385 tool pictured on page one used for? |
I have not see an example of VW385 in person, but I think it has a probe that attaches to the middle and some type of internal mechanism within the tool that redirects the in/out probe movement 90 deg then down the shaft to actuate the indicator that is mounted on the end of the shaft. Frankly I have to wonder if the P258 tool might be more accurate?? (less moving parts and potential for slop), but maybe a bit harder to use than VW385. |
Tony,
Did you consider making the G50 spacer for the G50 side cover? I'll take one as it looks like my next car (racecar) will have a 915. So the G50 spacer is not a must for me. But it'd be great if you could produce a G50 spacer since i'm sure i'll need one for a friend (or me) in the future. Thanks for putting in the time and effort on this repro job! >Kevin |
Kevin,
I haven't spent to much time trying to figure out what to do with the G-50's I have one in the shop now with the gearbox apart I could take some measurments. I would suspect it would be easier to just get a G-50 diff and machine it to work. |
Guy's looks like the three ready to go are sold pending payment. These people have gotten a PM so you know who you are. I'm taking 100.00 deposit on the next three I would like to have that by check and I will not cash it till they are done and the remainder is paid. I have about 5 more diffs to use then I'll need to start finding some I have to have the diffs from a 65-69 sandcast aluminuim transmission so if anybody has any to offer I'm interested.
Thanks, Tony |
check going out today Tony...many thanks again!!
Bob |
PM sent (I will take one from the next batch) :)
Tony,
My $100 deposit is in the mail. Thanks a bunch! |
Ok guys for the three guy's that paid for the tools they will be going out on friday I had a quality control issue with the block when they were milled they "sprung" and were causing inconsistent readings the have be redone in cold rolled steel and will keep there shape. I apologize for the delay.
Thanks, Tony |
thx for the update Tony... I await with full confidence and look fwd to receiving!!
Bob |
No problem.
I appreciate your quality control effort. |
No rush Tony. Thanks.
So, did this ever see fruition?
I sent a deposit. Never got a follow-up, despite a few asks, regarding when the next batch of tools would be produced.
Guys I will not be making anymore of these it turned out to b a lot of time and work that I can't dedicate to the project. Kevin I sent you a PM
PM rec'd and responded. Tony pointed out that my deposit (check) was never actually cashed. Mistake on my part in my check register, clearing it when it actually hadn't been cashed. So we're all square.
Sorry to see the tool won't be produced any more. I completely understand things like these take a lot of time, w/out much benefit ($). Nonetheless the effort and willingness to provide a tool that helps the DIY'ers is very gracious. |
I've got one of these that was never used. $500 shipped in conus if anyone is interested.
| All times are GMT -8. The time now is 03:51 AM. |
