SC Window
The driver's side window in my 82 SC jumped the track today.
Any tips, tricks, and/or advice as to how to repair?
Thanks in advance.
Old 12-19-2008, 01:58 PM
Window track........
Thanks in advance.
Bob,
I would bet that the culprit is the small securing bolt at the bottom track section and came loose. So an inspection is necessary. Open up the door panel and do a visual inspection. It will probably lead you to the problem. BTW, is it a targa or a coupe? Good luck......
Tony
Old 12-19-2008, 04:01 PM
thanks Tony.
it is a targa.
I have not removed a door panel before. Is it straightforward or wrought with peril?
Old 12-19-2008, 04:22 PM
grateful user
don gilbert's Avatar
its very easy, take off the top trim piece, (2 phillips screws on each end behind plugs) pull inner door handle out and unclip rod, remove 4 6 mill allen heads holding on pull stap, remove phillip screws holding on pocket and lid hinge, feel around where your panal clips are and gently pop them off, you door panal is basiclly cardboard, so be carful not to tear.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-19-2008, 04:43 PM
