fritzgator's Avatar
H.Freight master FI tester
Anyone have this model? It's $88@ the local store. Seems a safe buy, i.e. no electrical, and only one moving part to break. Here's the link.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97706
Gator
99 996 c4
Old 12-21-2008, 07:56 AM
GothingNC's Avatar
I would not trust that HF tool
Heard good things about the JC Whitney CIS fuel pressure tester
only $60
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 12-21-2008, 12:38 PM
3.2 CAB's Avatar
Gator, the link shows $79.99. I have a similar set-up that I bought from them many years ago, and it has worked and functioned as it should for its type of application. After I first received it I compared it with an OTC model, and did not see any thing that would indicate that it did not work properly or accurately. You just need to make sure that it is capable of testing CIS systems, as many don't. Several different, dedicated, CIS system testers are available, from various companies. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-21-2008, 02:34 PM
I have the JC whitney tester but I would not hesitate to use the one linked to.
Remember the setting is a range of pressure not a specific pressure.. if the guage is off slightly it really wont matter.
JP
'76 911s Ice Green Metallic bone stock
Old 12-21-2008, 02:54 PM
al lkosmal's Avatar
Gator, Try this one.
Al
http://www.jcwhitney.com/autoparts/Product/Pr-p_Product.CATENTRY_ID:2008126/c-10101/Nty-1/p-2008126/Ntx-mode+matchallpartial/N-10101/tf-Browse/s-10101/Ntk-AllTextSearchGroup?Ntt=injection+tester
RGruppe #669
http://www.x-faktory.com/
Old 12-21-2008, 02:55 PM
Looks exactly the same after all these years! WOW
JP
Old 12-21-2008, 02:58 PM
fritzgator's Avatar
Thanks,y'all. Better safe than sorry, i'm going with J.C.W model.
Gator
99 996 c4
Old 12-21-2008, 03:14 PM
Both made in China, I assume...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-21-2008, 03:16 PM
slodave's Avatar
The gauge from JCW says made in USA.
Old 12-21-2008, 03:28 PM
dlagerstrom's Avatar
I bought the HF model as I wanted something fast and JCW had a delay in shipping.
It worked fine for a while. Then I was getting strange results from my pressures. I ended up taking off all of the 'quick connect' pieces and just hooked everything necessary directly with fuel hose. Then it worked fine.
So, I like it for being in stock locally but not for how it works. It did provide me with what I need for CIS testing.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 12-21-2008, 06:12 PM
Harbor Freight does not sell a CIS pressure gauge set.
You may be able to rig something up to check control pressure with the set linked above but there is no ball valve in the hose for checking system pressure.
That set looks like something Harbor Freight marketed to unload a bunch of low grade chinese brass fittings on the masses.
I orderd the JC Whitney CIS guages some years ago, and for the $60 they sent me a set of total garbage early eightees 3/8 socket wrench extensions...
The fuel pressure gauge that comes up on the JC Whitney link above is not a CIS gauge set either. Harbor Freight sell that exact same one for about $10.
Thats a good deal for that but it doesn't do CIS.
There are no hoses to hook into the WUR loop, and it says not for CIS right on the box.
I sent the very poorly stamped out pot metal socket extensions back, and after many calls they eventually refunded my card.
You couldn't pay me to order anything from that BS place again.
Took a few minutes doing some internet searches and found this set for $56.95, and this tool store has good customer service.
It works perfectly.
Notice the small inline ball valve next to the T in the hose for shutting off the fuel flow through the hose that connects to the WUR so you can also check fuel head system pressure.
http://www.toolsource.com/fuel-injection-tester-bosch-p-93217.html?sourceid=trafficleader
Old 12-21-2008, 09:12 PM
al lkosmal's Avatar
You have to make sure that you order the correct set from JC whitney. They have two listed and only one of them is specifically for CIS.
RGruppe #669
Old 12-21-2008, 09:36 PM
CIS fuel gauges from JC Whitney.........
The old set is about 15 years old and got another one on Father's Day. Both purchased from JC W. Willing to give up the second set (new and never used yet) for $65 who might need one and does not want to wait for their back orders from JC Whitney. Happy holidays to everyone!!!!.
Tony
Old 12-22-2008, 06:11 AM
Actually, the kit from HF DOES include all you need for CIS including the ball valve. I just had a problem with the schrader valves they used for quick disconnect. I unscrewed the spring loaded pin in the center of the necessary pieces and had a very nice working CIS pressure tester.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 928
Old 12-22-2008, 07:09 AM
fritzgator's Avatar
Tony
Tony, I'll take that off your hands. JCW has a 3-4 week shipping delay and i need to sort out my Cold start issues. PM sent w/my info.
Gator
99 996 c4
Old 12-22-2008, 08:18 AM
The CIS gauge on the right looks just like the Star TU-14PB that I linked to at toolsource.. which goes for $56.95
It comes with a bag of extra brass fittings that are not in the picture. I leave the fittings that fit the Bosch WUR on the hose.
It also comes in a nice red plastic case and cost $8 less, and you can order it online or toll free number.
The bleeder valve on the aluminum block next to the gauge is important.
After it's all hooked up and the fuel pumps are running you wrap a rag around that and press it in which lets all the air out of the hose followed by some gasoline so you will then get an accurate fuel pressure reading without air pockets compressing in the hose and gauge.
After disconnecting it you hold it up by the gauge and press the bleed valve again to let air in through the bleed valve so all the gas in the hose will run out the 2 ends before you put it away.
They email you a tracking number, I had mine in less than a week, and you even get a warranty...
Old 12-22-2008, 09:59 AM
