mnmasotto's Avatar
I need help with anodized Fuchs
I have baked on water spots on the anodized portions of my Fuchs. I cannot seem to remove the spots with soap and water. I do not want to damage the anodized coating? Any ideas on what to use.
Thanks in advance, Mark
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 12-26-2008, 09:07 PM
the the is offline
There is no permanent repair you can do to the damaged anodized surface, but you can rub the anodize down with Vaseline and you can probably hide most of it.
Old 12-26-2008, 09:19 PM
Tsunamiboy's Avatar
If it is mineral deposits from hard water try water & vinegar.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 12-26-2008, 09:28 PM
Recreational User
porschenut's Avatar
Mark, petroleum jelly works wonders and removes the water spots beautifully. Just rub a light coating on and then wipe it down with a dry, soft cloth. The owner's manual recommends regularly using petroleum jelly to treat Fuchs wheels.
Old 12-27-2008, 05:59 AM
Regis turd ab user
Here's another product I use.
http://www.roadsters.com/gibbs/
Old 12-27-2008, 06:14 AM
Registered Cruiser
jorian's Avatar
Vaseline works OK on the anodized part (OK from 10 feet). Vaseline works GREAT restoring a little depth to flat black paint that is discoloured.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 12-27-2008, 10:23 AM
AirBorne!
A little PS21 polishing compound will work great. It is available from our host. I use vaseline as well. If it's cold outside, I find that it helps to warm up the wheels. I do this by removing the tire and wheel and putting both in a cardboard box into which I have cut a hole to put in a hairdryer. Leave it for a few minutes and the wheel warms up. I guess this opens the pours of the metal and makes it easier for the vaseline or PS21 compound to work into the metal.
wj
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 12-27-2008, 03:15 PM
mca mca is offline
mca's Avatar
If it isn't water spots it may be that some degreaser got on the wheels. I did this the first month I got my car. While cleaning up the tires some of the degreaser ran down along the anodized rim and ate up the finish. Unfortunately it can't be fixed.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-28-2008, 12:07 PM
