85 Carrera, things to do.
My car currently has 129,000 miles. The car is in excellent shape overall. I have been putting together a list of things that need replacement or refurbishment on my 85 Carrera. I have owned it for 13 years. I have searched through the site and done a lot of reading.
I have recently replaced the O2 sensor, & the head temp sensor, rear wheel bearings, CV joints, clutch cable & the helper spring.
I do NOT want to get radical with suspension or performance upgrades. The entire car is 100% factory original except the A/C system.
Here is my current list of maintenance and upgrades.
For the engine, new distributor cap, rotor, coil, fuel pump and engine position sensors.
For the suspension, new Bilistien HD shocks, turbo Tie Rods, ball joints, sway bar bushings, 21/27 mm torsion bars, and replace the suspension bushings with new OEM rubber. Refurbish the steering rack and pedal cluster.
Are there any special tools I will need. I have a good collection of tools but I don't have any suspension tools. I plan to do all the work myself. Are there any "while I am in there" upgrades or replacements I should look at? I am guessing the parts alone will be over 3 grand. It will take several weekends in the garage.
In the future a SW chip will be in order. I just don't want to spend the money for a SW chip on top of the money I am about to spend.
Any suggestions?
Old 12-27-2008, 10:46 AM
Zeke's Avatar
Top 10 Carrera upgrade suggestions
Old 12-27-2008, 11:40 AM
burgermeister's Avatar
You might want to do the 2-wire cylinder head temp sensor while you're at it.
Why replace the position sensors? If you're careful removing them and wrap the brittle insulation with some self fusing silicone tape, they ought to be fine.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 12-27-2008, 12:15 PM
deshetlr's Avatar
I'm a big H4 fan. Really cleans up the front end.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 12-27-2008, 12:20 PM
To each his own. I like my OEM sugar scoops.
The head temp sensor was updated to the 2 wire last spring.
I have fuses on the blowers, fans and the headlights. I have fuses on the instrument lights. All the easy fixes have been done.
Old 12-27-2008, 01:19 PM
steely's Avatar
I've been toying with doing a pre-emptive strike (refurb) of the alternator myself.
Have you considered replacing the vacuum lines?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-27-2008, 02:18 PM
kuehl's Avatar
Glen,
If you are going for the rack I'd look at the bushing on steering shaft.
And, you could always use a Kuehl Wirbelsturm evap motor; keep the garage cool on those
toasty days and nights.
Griff
Old 12-27-2008, 06:10 PM
3.2Carrera's Avatar
I am right their with you Glen!!!
-Joey B.-
1985 Carrera
http://www.pelicanparts.com/gallery/3.2carrera
Old 12-27-2008, 07:15 PM
old man neri's Avatar
Headlight relays if you don't have them already.
Caliper rebuild with brake system flush maybe.
Cat bypass pipe maybe? If you have your factory cat it may be getting clogged.
Old 12-28-2008, 02:02 PM
Nine9six's Avatar
Oh, and don't forget a new set of plug wires and a fuel filter while you're in there....
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-28-2008, 06:08 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
New rotors and brake pads are always a good thing, and check calipers and rebuild if needed. Everyone always wants to go faster, I like to be able to stop. Pretty inexpensive maintainence not to do.
Old 12-28-2008, 06:31 PM
zugelassener benutzer
teamfee3's Avatar
turbo/sport motor and tranny mounts?
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 12-28-2008, 06:42 PM
Headlight relays are done, I flush the brake fluid every spring. Pads are new calipers are fine. I replaced the plugs & wires last spring.
I appreciate all the suggestions on all the other things, but I was looking for things to do during the suspension changes. Invariably I finish a project and someone says "you should have changed the flummox capacitor to the new and improved type." Or "it is really easy to do that with this tool, but the way you did it is a real pain"
Old 12-28-2008, 07:56 PM
How about your fuel lines in the rear? What do they look like?
Old 12-28-2008, 08:25 PM
The fuel lines look nice and solid, no hint of wetness. They will be addressed next year when I plan an engine drop. I have a few minor oil leaks and I want to clean up the engine & the compartment. One project at a time!
Old 12-29-2008, 05:59 PM
