Danny_Ocean's Avatar
It works! Window Tint Removal
I had been scratching my head/nuts for a year trying to determine the best way to remove the fading window tint on my car. Most here had mentioned the "ammonia & black plastic" method, but I was skeptical. Trying to peel this stuff off was impossible and a razor blade made little progress. How the heck is a little ammonia gonna take this stuff off?
So today, I figgered...what the heck...I'll give it a try.
Let me say, the results are amazing! The tinting peeled like panties off a stripper. No glue, no nothing. There was a little left over on the edges where the ammonia didn't get a chance to soak, but the razor/windex took care of that.
Those of you similarly situated...don't wait! Just do it...
http://www.tintdude.com/remove.html
Old 07-04-2008, 05:37 PM
Komenda Fan's Avatar
Good to hear, I just need a hot day and the time to get it done...I can't wait, I think it will make a drastic improvement to my cars looks, once I get rid of the tint.
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 07-04-2008, 05:48 PM
Not sure how much the heat has to do with it, but it was 100F here today. I'm sure that sped up the process...I waited 45 mins. before peeling.
Old 07-04-2008, 06:00 PM
mark 74 carrera's Avatar
Would you consider tinting again? Did you remove due to its condition or do you not like the look of tinted windows?
Mark
Mark Isaak
1974 Carrera Targa - Light Yellow, Being driven
1974 Carrera Targa - Orange, Being restored
1974 Carrera Targa - Lime Green, Being pampered
2017 Macan
Old 07-04-2008, 06:05 PM
Mark
My car is all blacked-out, so yes, I will probably get them tinted again. The tinting was installed by the PO and, as with everything else he did on the car, it was the cheap stuff....turning purple, bubbles, distorted.
I had tinting installed on one of my work vans that is at least 10 yrs. old and it still looks good. I recall paying top-dollar for it back then. When I have the car tinted again, I will be sure of the quality of the tint.
Old 07-04-2008, 06:31 PM
Living up to the name
VroomGrrl's Avatar
Hello! I know I'm resurrecting an oldish post, but this is going to be my first winter project. Must get the crappy tint off my windows. Distortion out the back is dangerous, and the sides just look like hell.
So my question - and I have read the other posts & link you provided - did you have rear defroster lines to deal with? If so, how did that go for you? Any tips for that part? That's the only aspect of this that worries me.
2008 911 (997) C4 Carrara White
The sweet old 1988 911 GP White has gone to a new owner
"Keep your head in the clouds and your right foot mashed to the floorboard!" ~Village Idiot
Old 10-27-2008, 07:52 PM
the the is offline
This method works great, I've done it several times.
You don't need to worry about the defroster lines. The tint will peel right off, leaving a spotless clean glass behind.
The main thing is to just get good coverage with the ammonia, and let it soak a bit (20-30 minutes will do it on a warm day). If you do that, you won't have a speck of residue left, just peel and go.
Old 10-27-2008, 08:14 PM
VroomGrrl's Avatar
Great! That's what I was hoping to hear. It's only getting into the 50s here now, not sure that'll be warm enough to melt everything. I'll have to be on the lookout for some warmer days (they always come down here until January or so). Hopefully we'll get a few more days in the 80's and I will go for it. Thanks!
Old 10-27-2008, 09:03 PM
MIK911's Avatar
That's good to know--that it works well.
I've been contemplating this for awhile, but didn't want to get stuck in the middle with partially removed tint
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 10-27-2008, 10:43 PM
oneblueyedog's Avatar
Originally Posted by danny_ocean View Post
the tinting peeled like panties off a stripper.
lol.
78SC coupe, Silver Metallic
Old 10-28-2008, 04:52 AM
All I ever used was a heat gun.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-28-2008, 07:28 AM
I removed the tint with a steamer designed for removing wrinkles from clothes. I bought the steamer at "Bed Bath and Beyond" for $29.00. To me it was money well spent.
It worked fast (three windows in less than 20 minutes) and left no residues. You work the steam over the tint from the inside of the car and the tint peels off the window in one big sheet. No worries about the rear window defroster grid either.
You only have to take care not to scald your fingers when you start peeling the tint.
1980 911 SC
2017 Suburban
2022 Mercedes 450E - Wagon
2011 Jeep Wrangler
Old 10-28-2008, 11:32 AM
VroomGrrl's Avatar
Did you have a brake light assembly on the inside of the window to deal with? If so, did you remove it, or work around it?
Old 11-04-2008, 08:32 AM
I did not have a brake light assembly to work around. I most recently did this (in September) on my daughter's VW Cabrio and removed tint from the two back passenger windows, as well as the rear window. The rear window is glass with a window defroster and it was undamaged by this process.
I suppose that removal of the brake light assembly would depend on if the tint was installed in-between the glass and the light, or just cut around the outline of the Brake light assembly. Either way, the steamer gets the tint off with minimal effort and no residue on the glass....and no need to work with what I expect would be smelly ammonia solutions. The steamer does make this process very simple.
1980 911 SC
2017 Suburban
2011 Jeep Wrangler
Old 11-04-2008, 09:10 AM
VroomGrrl's Avatar
Thanks so much for your input. This is what I see out of my rear window at dusk:
I am going to pick up a steamer and give this method a try.
Old 11-04-2008, 09:31 AM
Throw it on the ground!
Next summer, you'll wish you still had that tint on there. I helps alot in reducing the cabin heat temps .......A/C will never keep up.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-04-2008, 09:46 AM
I removed the tint for the same reason. Backing up at night was a guessing game! The dark tint made it impossible to see out any of the rear windows.
The summer heat is more forgiving where I live, so off with the tint!
1980 911 SC
2017 Suburban
2011 Jeep Wrangler
Old 11-04-2008, 10:49 AM
the the is offline
While the ammonia method works great, I'll try the steamer next time. The downside to working with undiluted ammonia is it is really foul smelling, if you catch a whiff of it it can be enough to knock you down! You also have to be careful to not get it into the interior.
Old 11-04-2008, 10:52 AM
VroomGrrl's Avatar
Having driven this car home from Houston in July, I can tell you that I would rather be able to see at night!
The AC in this car sucks regardless. I may get a better tint job at some point later but only if the technology has really improved so that night visibility is not so compromised as with my current tint.
Old 11-04-2008, 11:19 AM
Visibility is bad when backing up even without tint. That's why I installed a back-up camera.
Back-up Camera on a 911?
Mark
1987 911 Coupe
Old 11-04-2008, 11:26 AM
