Banned
cost to reseal engine from leaking
hello
Interested in purchasing a 964, runs drives good, but leaking oil,
what is a estimate to reseal the engine
thanks
Old 01-01-2009, 08:02 AM
Somatic Negative Optimist
Gunter's Avatar
A lot depends on the year and Mileage.
Anywhere from ~3-10k plus.
The 964 had leak-problems with missing head gaskets from '89-'92? and that's a major cost to rectify.
With high Mileage, a 3.6 liter would also need additional work/parts and not just a reseal.
If someone does it cheap, they'll be sorry later on.
Have a shop with 964-experience look at it to determine if the heads are leaking etc. and ask for a leak-down test.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-01-2009, 08:41 AM
Sports Purpose 911 Driver
mjshira's Avatar
this question is very vague and thus tough to reply to. recommend you post some pictures, more info on the car, etc.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-01-2009, 09:18 AM
you should get a couple rec's from guys here about where to have it PPI'd in CT. Then use the findings to negotiate your price. At least you'll know what you're buying.
Tony G
2000 Boxster S
Old 01-01-2009, 09:21 AM
Slumlord
Porsche_monkey's Avatar
Not a practical purchase unless you can do the work yourself.
Or look at it this was, say the car is cheap $12,000, maybe? You get stiffed for $10,000 on the engine, is it now a $22,000 car? Nope, it's a $17,000 car. You just threw away $5,000.
But, buy the car for $12,000, re-seal the engine yourself, spend maybe $3,000, then you have $15,000 into a car that could fetch $17,000.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-01-2009, 10:23 AM
I paid 6k. This included pulling the engine and some component reasembly. I agree w/ the suggestion to PPI and use as a negotiating tactic.
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 01-01-2009, 11:00 AM
As Gunter says, it depends so much on mileage and condition. Having done plenty of 964s with various mileages and conditions, if it is leaking that bad it also may need plenty of other stuff.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-01-2009, 02:04 PM
Banned
yes i will take on lift, lets hope it a valve cover, or oil tubes , it also has some paint clearcoat peeling on the roof which is going to need a repaint , car has about 200K it which makes me think ,someone took good care for this car for sometime
Old 01-01-2009, 02:25 PM
Gunter's Avatar
Sounds like wishful thinking: 200k and hoping for minor leaks?
A lift will tell you nothing unless someone with real 964-experience checks out the whole story, including a leak-down test.
There are many, many areas and parts that can leak and just looking at the engine from underneath does not give you the source.
If you do just a cheap PPI, you'll be sorry later.
Any history about major work done on the engine?
What year is this 964?
Old 01-03-2009, 09:20 AM
Slumlord
I think Dr. Gunter is being a realist. In general, cheap cars are cheap for a reason.
I still think $3k is likely do-able on your own, and $10k is likely if you are just cutting a check to a mechanic.
84 Cab - sold!
Old 01-03-2009, 10:18 AM
Send a message via Yahoo to Lukesportsman
The only thing I will differ on potentially is the new value. A lot here depends on your expected ownership. I'd rather have a "fresh" $20k car than a $17k unknown car. Just because the $17k car doesn't need an overall yet, its still somewhat a dark horse. If you can buy it right and plan to keep it for years, then this may still work out in your favor.
Just get good PPI's and don't go in blind. Know what your getting into and it could be a fun/learning experience. If you get caught blind sided, that is when it hurts. If this didn't make some sense to many of us here, we wouldn't be restoring long hoods or all the other fiscally silly things. Just don't kid yourself and do it right so you won't continue to have issues and end up hating her in the long run. You'll have a low $20k 3.6 car that should be dependable into the distant future. This of course is assuming your getting it quite cheap.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-03-2009, 12:01 PM
