Southern Class & Sass
Son of a... (oil leak)
Allow me to vent,
Murphy has struck. My new rear main seal is leaking. I replaced the original seal while doing the top-end on my '88 last winter. The old one was weeping, and since I was there I figured it should be attended to. Now the new one leaks worse than the original ever did. I used the OEM seal I bought from Pelican. I was careful to not install it too deep. Still, something went awry. 1,200 miles later I have a Porsche that marks the garage. Oh well, another project...
Dixie Bradenton, FL 2013 Camaro ZL1 |
Friend of Warren
Did you lube the rubber lip before installing it? Was there a groove on the crank from the old seal?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Somatic Negative Optimist
Also, some people like to install it without Curil-T to prevent it from being pushed back out?
I think JW mentioned that one time.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I lubed the lip that runs against the crank. Otherwise, I installed it dry. I don't recall seeing a groove. I wonder if it would help to use Curtil on the outside edge of the seal? Or maybe a good strategy would be to install the new seal just a touch proud of the case?
I've got a track weekend coming up (12/5, 12/6). After that I'll drop the engine and see what's up. Hopefully it's not a leaking case.
A touch proud or whatever. Just not on top of where the original seal ran for so long. That's what they tell me anyway and it's worked on the 4 cyls I've built.
Sorry to hear. Where does this leak show up externally such that you know that is the source? Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
outside dry when installing. may be something else like case 1/2 seepage, which is common in that area. mainshaft seal maybe? does it smell like gear oil?
Are you sure it was OEM? I brought a Bosch Relay from our sponsor it it said on Bosch on the box but it also said MADE IN CHINA. Now I know for a fact that back in 82 Porsches were built with parts MADE IN GERMANY.
Not to blame our host, but companies seems to be looking at the bottom line and the bottom line is you produce your products in a country that can produce it for the cheapest cost. |
I bought a MAF sensor for another car from ebay a week or so ago, when I got it it looked a little odd, on examination it was a poor quality chinese copy.
It even performed badly, I don't know why everyone talks about free trade being good, all the chinese do is dump crap on our shores and laugh at us when we complain about human rights and pollution.
1997 Boxster SOLD 1999 R1100S SOLD 1988 Carrera 3.2 |
It might be hard to tell if you don't sniff it. Doesn't Brad Penn look similar to Swepco? I installed my RMS dry and it seems to be holding fine - but I only have 2400 on the rebuild. Let us know what you find.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
SCWDP- Shock and Awe Dept
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Ryan...what do you think happened in your case? This has me a little stressed since I'm about to re install my 3.2...
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I've taken to putting flourescent dye in the crankcase oil ( made for the purpose ). then it's easy to find leak locations with a blacklight. I found it hard to see the exact start of a leak with clean, clear oil. got it at the GM dealership.
Throw it on the ground!
I'm preparing for an engine swap and have been building a parts list to replace all the usual suspect gaskets and seals. Posts like this make me think it might be best to leave the RMS alone unless it is already leaking. (58k on the replacement engine).
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
It's definitely oil. Nice green Brad Penn oil.
So far i can only tell where it's not leaking: cooler, thermostat, breather.. It's either the flywheel seal or the shaft seal. I'll have to pull the engine to tell exactly what the cause is. Oh well, hopefully it's a leaking seal and not a leaking case.
Wow Ryan, that's some leak...
resident samsquamch
Hang in there! That is indeed one of the most frustrating sights, Ryan!!!!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Slumlord
If you pull it make sure the outer diameter is not oval. Mine was and it had to be machined and sleeved.
And my driveway looked just like that ^^^ the first time I drove it.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Sports Purpose 911 Driver
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
