Have few questions about shifter
I have a lot of space between gears when shifting, I go from the dash board to the seat. Is there any way of improving the distance between gears? What is the difference between a short shifter and speed shifter?
Old 01-06-2009, 05:22 AM
sudo apt-get purge 930
equality72521's Avatar
Search for wevo shifter and hargett and you'll get more than you bargain for.
--clutch-monkey
Old 01-06-2009, 05:26 AM
At the track = great day
ChkbookMechanic's Avatar
Don't forget there is also Rennshift and the Porsche factory short shift kit as well...
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 01-06-2009, 05:33 AM
will a short kit kit improve the difference?
Old 01-06-2009, 05:38 AM
Tim
Send a message via MSN to tvanbroekhoven
The shortshift will improve it a bit.
I have bought the Rennshift because I found the Porsche shortshift kit too sloppy. I didn't even knew I had one until I removed it
Rennshift is very good and easy to install!
Old 01-06-2009, 05:43 AM
The WEVO and Rennshift kits should shorten the throws 33% or so.. I think the Rennshift has the ability to switch between 33% and like 22% shorter throws. Both of these kits also add a centering spring to the shifter so it will sit in the 3-4 plane while in neutral.
I have the WEVO and love it, even though it is harder to install than the Rennshift. I also know people w/ the Rennshift and love it..
I don't know much about the Hargett, but you probably can't go wrong with any of them.
Lane
Old 01-06-2009, 06:41 AM
Be careful with short shifters of any brand that shorten the throws too much. There's no free lunch. The shifting effort increases proportionally as the shift throw decreases. In addition, the quicker shift (up or down) can rush the finicky synchros, causing premature wear.
Sherwood
Old 01-06-2009, 10:53 AM
Thanks for everyone's advise, i'm going to check into the purchase.
Old 01-07-2009, 05:19 AM
kodioneill's Avatar
i have a short shift kit to sell. $45.00 shipped.
you should check all your shift bushings they are most likley worn out. out host sell a nice kit for this. if you replace all the shift bushings and install the shift kit it makes a very tight shifter.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-07-2009, 05:27 AM
What kind of shifter is it that your selling? I've been looking for a kit for my 915 too.
Old 01-08-2009, 10:56 AM
RS 73
that looks like a weltmeister kit. I feel the factory kit is better. It includes all new mving parts. I had a weltmeister and it was OK, but not compatible with the Wevo shiftgate I put in my transmission.
I would start with replacing all the plastiv bushings. Including the shift rod connector.
Dick Lague
RGruppe #79
1973 RS Spec Carrera
2001 Saab 95 Aero
2003 Saab 95 Aero
Old 01-08-2009, 12:02 PM
gtc gtc is offline
abides.
gtc's Avatar
Does anyone think you actually shift faster with a short shift kit?
The advantage I see with my Wevo is less travel between shifts. My stock shifter shifted just as fast (time between gears).
Graham
1984 Carrera Targa
Old 01-08-2009, 12:10 PM
zugelassener benutzer
teamfee3's Avatar
I had the Weltmeister kit in my 914 and the shift lever was too short but the throw was good. For everyday use those kits are definately different, tighter, shorter, so make sure you really want that. The factory kit in my '86 Carrera is shorter throw but sloppy is a good description.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 01-08-2009, 01:03 PM
kodioneill's Avatar
it is a weltmiester.
1982 chiffon 911sc
Old 01-09-2009, 06:50 AM
emac's Avatar
Rick
Before spending all sorts of money on a short shift kit, please invest a few bucks and replace the cup bushing at the end of your shifter. Then replace the coupler bushings and adjust the coupler per the many postings on this site. I think you will be quite supprised at the results. The 915 takes a while to get used to and even longer if something is out of wack.
Ernie 81 SC
Old 01-09-2009, 10:36 AM
Recreational User
porschenut's Avatar
I don't. The difficulty with the 915 is in the balky synchros, not the shifter. A short shift kit won't speed anything up. Maybe it reduces wear and tear on your elbow.
Old 01-09-2009, 11:35 AM
arbita1's Avatar
I installed the factory short shift. At first I wasn't happy with it and was immediately looking into the Wevo and Rennshifts to replace it asap. The short shift was actually worse than my original shifter.
But then I realized I didn't have it adjusted properly and the ball cup that holds the shift lever was very loose. I tightened that up. Adjusted the shift coupler. And now I love the factory short shift. It feels like it must have felt when the car was new.
I still would like to have the Rennshift or Wevo...but I don't feel like I "need" it now.
My point I guess is that sometimes it just takes some tightening or adjusting to get something to feel right.
Matt.
83 911SC
85.5 944 NA - Sold
Old 01-09-2009, 11:51 AM
I agree, before I installed my WEVO shifter and shift coupler I readjusted the coupler and it really helped. Of course, then I installed the WEVO shift coupler and I was surprised how much slop just the WEVO shift coupler removed from the stock shifter. Finally, about 2 months later I installed the WEVO shifter and it really made the car shift the way I thought it should.
Lane
Old 01-09-2009, 11:58 AM
