3 restos WIP = psycho
kenikh's Avatar
I can buy it at the local paint supply store, right down the street from work (Wesco). Lemme know if you need a hand.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-30-2009, 01:25 PM
AutoBahned
RWebb's Avatar
Thanks. Maybe I'll start a "spot" rust treatment thread...
Old 01-30-2009, 01:45 PM
AutoBahned
RWebb's Avatar
BTW - this is what the pedal cluster looked like before - hard to see anything wrong with it...
Old 01-31-2009, 09:04 PM
For stuff like that I use Rust Mort then a coat of etch primer, RM makes a good one (both from an auto paint store), topcoat of your choice.
I would not use Por15 on a wheelbarrow.
JPIII
Early Boxster
Old 02-01-2009, 01:22 AM
al lkosmal's Avatar
I wire brushed mine and applied POR-15. Worked very well.
RGruppe #669
http://www.x-faktory.com/
Old 02-01-2009, 04:55 AM
egertk's Avatar
I've got my POR-15 and metal ready before through NAPA. Might check them out.
Old 02-01-2009, 02:13 PM
AutoBahned
RWebb's Avatar
Thx - I finally found some - $42/Qt. No thanks to that. I am using a Rustoleum primer and paint. That should last 30 years, at which point it is someone else's problem...
Old 02-01-2009, 04:08 PM
Sports Purpose 911 Driver
mjshira's Avatar
I've found it at PepBoy's before.
Great thread, now, I thought only young guys 'street raced'? ;-)
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 02-01-2009, 04:47 PM
AutoBahned
RWebb's Avatar
oh no - don't get the wrong idea - I obey all speed limits and traffic laws at every moment.
Old 02-01-2009, 06:43 PM
mjshira's Avatar
What would Shultz say? 'I know NOTHING'!
Old 02-01-2009, 06:55 PM
burgermeister's Avatar
Our local independent auto parts store has a competitor's product (forgot what it's called) in 4 or 8 oz wee cans for $10. Perfect for such jobs, since the whole can has a tendency to turn into a solid glob of hardened goo once it's been opened....
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-02-2009, 02:06 AM
AutoBahned
RWebb's Avatar
OK, any thoughts on why somebody would weld this thing on there?
Old 02-02-2009, 01:12 PM
DW SD's Avatar
WOW, I'd just try to source a nice clean one, rather than fixing that thing.
Looks like someone welded a stop on there, but it is just speculation. Or maybe it was for the brake switch?
Doug
1971 RSR - interpretation
Old 02-02-2009, 01:29 PM
Zeke's Avatar
The person who did that might have thought it was a way too adjust the brake pedal lower for heel and toe. Instead, it looks to me like he was reducing overall pedal travel. That could have had some serious ramifications under stress.
Old 02-02-2009, 01:35 PM
AutoBahned
RWebb's Avatar
Pedal Cluster – Major Parts
info from Pelican catalog
no shaft listed for ‘73
911-423-027-01 - Pedal Shaft, 1974
911-423-027-03 – “ 1975
911-423-027-04 – “ 1976
930-423-027-01 -- “ 1977-86
from PET pgm version () =part ID. – for ??
(21) 911-423-219-03 – spacer
(22) 911-423-065-02 - bearing bracket (bottom “cup”) –
(25) 901-423-250-02 – reverse lever, front (has 3 connections on it)
(28) 901-423-035-00 – bearing tube
(33) 911-423-027-01 – clutch pedal shaft (1972-on)
(35) 901-423-312-00 – clutch pedal, lower part
(40) 901-423-053-02 – brake pedal
(42) 901-423-531-00 – return spring
(43) 901-423-507-02 – intermediate piece
TRE says - Clutch actuation shaft is different between a 70-71 and 72-75; otherwise all is same
Old 05-26-2010, 06:02 PM
AutoBahned
RWebb's Avatar
36 parts on this diagram
Old 05-26-2010, 06:03 PM
AutoBahned
RWebb's Avatar
Take a look at the roll pin and the rusty bottom of the pedal cluster cup. NONE of this could be seen in situ. I had gotten down in the footwell with a flashlight after taking the floorboard out to inspect it and could not see any of this.
Old 05-26-2010, 06:08 PM
AutoBahned
RWebb's Avatar
Note that these brake hoses are not well sealed - this is something else one should check periodically.
Old 05-26-2010, 06:10 PM
AutoBahned
RWebb's Avatar
The best way to check is to put a trouble light up under the F suspension pan. (I did this while rebuilding the F susp., which is why the pedal cluster stuff is oddly in this thread & not the interior thread). Then darken the footwell area and the light leaks show your water leak areas. Note the circled area and compare with the last pic.
Old 05-26-2010, 06:13 PM
AutoBahned
RWebb's Avatar
Here is a pic of what the apparently nice & clean footwell area looked like after I removed the pedal cluster.
So, folks, be SURE to remove the pedal cluster every few years and check it out -- inspection with the piece in situ is not adequate.
Here is a pic of one unfortunate person's pedal cluster area:
Don't let that happen to you. Pull it out and check.
I treated mine with rust reducer and then with a Rustoleum primer on top of that.
Then I put a top coat of black paint over that.
Old 05-26-2010, 06:17 PM
