Stuborn CV's
Has anyone had the problem of the axles coming loose on them?
The bolts on my axles kept backing out all last summer. I was constantly tightening them about every 2 weeks. What a major annoyance. I finally got them to stay tight with lock washers from my work, but I'm not convinced that is going to fix the problem. |
Yes, I did but that was when I did not install them correctly. My guess is your threads and bolts are all worn out. I propose that you chase them with a tap and die, then reinstall with a touch of blue loctite, and torque to specs and then all will be good.
I have never had one back out after that regimen. I do not use lock washer, or schnorr, or safety wires.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The problem with the CV bolts backing is the CV grease getting on the threads. You need to clean the threads spotless of grease using brake cleaner and q-tips. Do a search on this site there is a long post all about CV joints and bolts.
Good luck, John |
AutoBahned
Do what John said, and be sure to use NEW Schorr washers on them. If there are no moon plates then buy some. Inspect the bolt threads and the inset wrenching fixture on your bolts. If they are OK, then clean carefully and reuse. If not OK, buy new bolts, aka cap screws. |
Somatic Negative Optimist
CV's are not stubborn, they work fine if torqued correctly with Schnorr washers as intended by Porsche. It would help if you let us know what type/year? Four 10mm bolts, or six 8mm bolts? Moon-plates? What torque are you using? Going cross-wise with a pre-torque first or?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
It's a 79 SC. It's Six bolts, 8MM, and I'm using lock washers and no moon plates. It didn't have any on there so I didn't install any. I haven't had any problems since i put Knew bolts and lock washers. Maybe that will fix my problem.
AutoBahned
split ring lock washers are not adequate - must use Schnorr
need moon plates too - regular sheet metal cup forming the CV housing is not adequate |
Fuchs w h o r e
In extreme cases, the threads in the flanges get wobbled out. If that has happened, no amount of tightening or loctite will give you a reliable connection. Replacement is necessary.
The initial cause of the bolts backing out is improper torque. The CV bolts take a lot more torque than most mechanics are used to. A torque wrench is manditory. |
How do you know when the bolts are comiing loose, other than checking? is there a clunk, or any other sound?
'71 911E Targa |
The bolts for the CV's; are they not "stretch-bolts"..?
I thought they were intended to get torqued properly once, and that one time they will stretch a certain amount, keeping a constant pull on the two surfaces. I was told that old bolts should be replaced because these caracteristics change over time. Anybody know for sure? |
Slumlord
They are torqued, so technically they aren't stretched. I think.
All bolts are stretched, but stretched usually means torque to xx ft-lbs then rotate yyy degrees. (Like a head bolt). Still, in this application I would consider replacing them if they have been a problem.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
The first time time they came loose and me I was racing a car down the highway and the axle came off. Wow. What a noise. After that i was checking them routinely and noticed they were backing out. So i took them all out, replaced all the bolts, chased threads, and reinstalled the new bolts and washers. I never noticed any vibrating or noises until the axle cam off at 100mph. Thanks for all the info guys. I love this forum.
AutoBahned
- Jim Sims said no to both above & he should know -- search on his name and CV (use google) or name + joint + bolt in this search engine |
AutoBahned
I re-torque after re-installation + 100 miles; same on wheel lug nuts. There is a long thread on all CV joint issues - started by Randy Cecale. rececale or rcecale |
THE IRONMAN
Lockwire them, you'll never think about'em thereafter.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
AutoBahned
a search will reveal why that is not a great idea....
What torque are you using? 8 mm need 29-30 ft-lbs Pre-torque first all around, then the final. These Allen bolts should be 12.9 tensil strength and they don't stretch. Split lock washers are not the best for this. Are you using gaskets? Or metal on metal?
