f3nr15's Avatar
Question Removing under-dash AC console
Hi all;
Am in the process of removing the bits and pieces of the useless AC in my mid-year car.
I have the under-dash style vents which are screwed in to the knee pads. The vent console has a wiring harness which seems to disappear in to the bottom of the car.
I'd like to remove it intact in case someone wants the vent console; can anyone advise as to where the harness inserts? Should it simply "unplug", or will I have to chop it out?
TIA!
EDIT: They are the Behr thin vents...
Regards,
Peter
1992 928 GTS
1993 964 Carrera 2 Coupé
Old 01-11-2009, 04:57 PM
rodoredas's Avatar
Hi Peter, i've recently done this on my mid year, you should be able to get the harness out in one piece, the harness should go back to a relay, mine was mounted near the fan motors, and the fuse box. make sure you disconnect the battery terminal before you start mucking around.
I think I've some pix at home if you want.
cheers
Shane
1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500
1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158
Old 01-11-2009, 06:05 PM
f3nr15's Avatar
Okay, thanks Shane - pics would be great!
Regards,
Peter
1992 928 GTS
Old 01-11-2009, 06:08 PM
rodoredas's Avatar
Peter, these are not the photos I thought I had but might help, I have bigger versions of these if you want I can email separately
cheers
shane
Shane
Old 01-13-2009, 02:23 AM
f3nr15's Avatar
Shane, that's brilliant!
Just PMed you with my email address, if you could forward through the high-res photos, I would be most appreciative.
Regards,
Peter
1992 928 GTS
Old 01-13-2009, 04:46 AM
