Why won't my intermittent wipers work anymore?
They worked, now they don't. ? 79 SC
Relay
Member 911 Anonymous
Key is in the ON postion, correct? Does you regular wiper work? If not check the fuse or relay.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
when the points in the wiper switch don't contact with the switch off, the wipers don't park and the intermittents don't work.
The newest of the noobs!
I don't see a problem with this. My intermittents don't work nor do they park correctly. However, I like that I can park them on the passenger side, and the wife can look at them instead of me!
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
+1. If your wipers don't park, you need to take the switch off the steering column, and re-bend / sand to fresh metal, on the switch contacts. Once the wipers can park, the intermittent function works as well. If your wipers still park fine, maybe it is a relay or rheostat.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
My wipers park good, and they work fine. Just the little dial by the guauges when I turn it nothing happens.
1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels |
The intermittant feature only works when the wipers are parked in the off position, not while they are on low or high.
RETIRED
Fix the intermittent, then pop the tach out and reposition the arm to move the park position to the passenger side.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
