Interesting dash bulb scenario
I am new to the board and the 911 world. I want to thank all of you who post here as it has been a great help in repairing some of the issues with my 83 911SC.
I wanted to share my recent experience so as to possibly help some other poor soul working on his car. With all my searching I couldn't find this exact situation. My car was not charging so I went through all the suggestions and tech tips I could find on this site. After checking everything and nothing really needing repair I was at wits end and still had not found the problem. In addition the car was not idling very well and I had read all I could about CIS knowing that would have to be done as well. Since I had decided to tackle the CIS after the charging problem was solved that really became secondary in all my diagnosis to this point. Not really understanding the dash light and all of it functions I dismissed it as merely a blown bulb (think american car) and moved on the hard parts. To make my miserable story shorter I will say that the bulb must at least function for the car to charge properly. Apparently it completes a circuit necessary to excite the alternator in to a charge state. The great thing is my CIS now works wonderfully. I had not read where voltage affected the idle, only all the other issues (vacuum, sensors and so on). Once the voltage was brought up by the working alternator my idle quality was immediately restored. Now I only have a cold start issue that is really minor. Needless to say, I was happy to spend .69 cents to fix my charging and CIS problems all in one! This is not my typical luck. David
1983 911SC Targa 1968 Camaro SS 2007 F150 FX4 2006 Honda Shadow Sabre 1988 Honda Hawk GT 1965 Honda S90 |
Wow....I thought crazy s++t only happened to me! Glad you got it worked out. Do yourself a favor and go buy another bulb and throw it in the glovebox.
Trust me. I bought 3!
Detached Member
What bulb? The alternator light bulb that comes on when the fan belt breaks?
Hugh |
Soldier of Fortune
I find this hard to believe. A 911's entire charging system can be disabled by a .27 cent bulb?
Hmm... |
Born to Lose, Live to Win
i believe i have read threads or posts on this same subject here somewhere and that its true
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 Last edited by ramonesfreak; 01-14-2009 at 03:42 AM.. |
Soldier of Fortune
I did a search and found this from "Early S Man": The warning lamp must work for the field windings to get their pre-excitation current. Could be a loose or corroded connection at the warning lamp holder, corroded/oxidized lamp holder, corroded connection at terminal #11 of the 14-pin connector, fractured Blue wire under the insulation, or loose/corroded Faston connector at the brush holder of the alternator. Clean all of the above connections and see if that helps. My suggestion, if the above doesn't work, is to run another wire outside the car from warning lamp to the engine side of 14-pin connector ... if the warning lamp comes on with ignition switch on, the you know the problem is between dash and 14-pin connector. If you have to run the 'new' Blue wire all the way to the brush holder D+ Faston tab to get the warning lamp to work, then the break in the wire is in the engine harness. Wow. Learn something new every day. And, what a crappy design! |
DasBoot and Dave231, you have personally discovered something more important than the solution to Dave231's problem, you found the treasure trove of information that is honored at the top of this page--Warren Hall. Dave231, welcome to Pelican, and take a bit of time to search Warren's name and discover the depth and breath of his knowledge, as well as the depth and breath of the respect he has on this forum. He is truly missed by all.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
with the blown bulb the alt wont charge as you know. the warm up regulator will not lean out when the alt is not working as it gets it's power from the charging circuit.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Thanks LJ. I have read some of Warren stuff without realizing it. I appreciate all the posters here, it seems to be a great community.
Goldfinger
Anyone know if this problem is the same in newer 911's (2000-2001)?
A friend of mine just bought one and it has charging problems that the previous owner did not disclose. After calling him; he said that he never could figure out why he couldn't keep the battery charged. Nice guy huh?
1984-Carrera (pewter metallic) |
Sports Purpose 911 Driver
Welcome to the community!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
simply: it's "part" of the circuit.......
good find! Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
1983 911SC Chiffon Weiss
Regards, mlfox |
