Is my car overcooled?
The car is a '79 SC with a recently rebuilt motor and a front mounted B&B oil cooler that was installed because the old engine overheated when pushed.
Now, during normal driving the temperature needle stays pretty much at the very top of the white box and does not leave the box.
I also recently did an oil change immediately after driving and the oil was cool enough that I could keep my hand in it without it feeling objectionably hot.
What are your opinions?
Thanks for reading.
Old 01-07-2009, 02:56 PM
Temp. gauge at 8:00, 9:00 or 10:00 (using a clock as your reference)?
2011 Cayman Speed Yellow
1988 924S (Sold) 2000 Boxster S (Sold)
2006 Cayman S (Sold) 1990 964 C2 (Sold)
1978 911 SC (Sold)
Old 01-07-2009, 03:05 PM
This photo will give you an idea what temps you are running. I would be thrilled with your temps.
1978 911 SC (Sold)
Old 01-07-2009, 03:22 PM
Typical Salesman
jeffrey2's Avatar
Subscribing as mine never goes above the 8:00 under SoCal heat.
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 01-07-2009, 03:28 PM
Just checked the side of the gauge with a flashlight. Looks like my oil stays around 60 degrees - can't even make tea with it...
Old 01-07-2009, 03:33 PM
old man neri's Avatar
When I drive mine the real cold it just slightly hovers over the thick bottom white mark in 'style b' and I too was also wondering if this was too cold. Was considering blocking off part of the rear grill with cardboard.
Old 01-07-2009, 03:34 PM
Bill Verburg's Avatar
The calibration #s are located over at the edge of the guages, you can see them in the above pics but not read them. So go to your car and you should be able to read those, us older guys would want a lit magnifying glass to do so.
I wouldn't be concerned at the top of the white box as in style A above. That should be ~180*F. The B&B front mounts are so efficient that they keep the engine at the opening temp of the T-stat. Even my 3.8RS ran at that temp during normal street use an 90*F days.
If you track the car the temps will go somewhat higher but that is normal as long as the temps stay under ~220F, which they likely will.
The only down side of running at ~180*F or so is that the oil should be changed a little more frequently, I was comfortable w/ once a year, ~2500mi.
Bill Verburg
Old 01-07-2009, 03:39 PM
My gauge is like in style A and I looked at the edge of the gauge with a flashlight and it seems that I am operating at around 60 degrees Celsius, or 140 Fahrenheit.
Is that too cold?
Thanks to everyone for posting and for those great images of gauges.
Old 01-07-2009, 03:44 PM
Band.
Is it possible the t-stat for your front cooler is stuck OPEN?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-07-2009, 04:08 PM
Old Member
Is that too cold?
It's my understanding that oil should be heated to a bit over 212 F so the water in the system is boiled off.
Water enters the motor & oil system on most mornings (we see it as dew), unless the car never leaves a heated garage.
Clifton Brown
https://www.mancalamarketing.com
Old 01-07-2009, 04:16 PM
MindtrapX's Avatar
I have been curious about this as well. My gauge is style B and the highest my temp gauge gets is the top of the large bottom marker, same as neri. I have white gauges, and never noticed an actual temp reading on it. I'll have to take a look when I get back in town on Friday...
Kevin
'84 Carrera RoW Coupe
"I'd like to offer moral support, but I have questionable morals"
Old 01-07-2009, 04:30 PM
db_cooper's Avatar
The oil temp needs to get up to 212* to burn off H2O. The good news is even though your gauge is reading low, the piston and rings are very hot. So once up to your low operating temps, oil on the cylinder wall and pistons is very hot and burning off H2O and other undesirables in the oil.
The only problem you must drive the car for 30 or 40 minutes to get the oil completely circulated.
Old 01-07-2009, 04:49 PM
Happiest when Tinkering
gsmith660's Avatar
My oil temp dosen't seem to come off the bottom peg but if I take the oil filler cap off after a drive I can see vapor coming out when I check the oil level. My gauge worked fine before the big oil cooler because it told me I had just hosed my motor by overheating it.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 01-07-2009, 04:52 PM
The temp doesn't have to get to 212F to evaporate water/fuel. Mine sits at 80C except on very hot days where I have seen just over 100C....2 drivers at an AX.
A mag case motor will "love you long time" for that.
JPIII
Early Boxster
Old 01-07-2009, 05:23 PM
water does NOT need to be heated to 212F to evaporate, What non sense.
It's true that the hotter it is the quicker the evaporation process goes and it's true that water boils at 212F at STP but it is evaporating away even at room temp.
Bill Verburg
Old 01-07-2009, 06:44 PM
Crotchety Old Bastard
RarlyL8's Avatar
Good point Bill. An extreme example is sublimation - the physical change from ice to vapor as you see when ice patches on an asphalt road slowly vaporize on a very sunny winter day.
Old 01-07-2009, 08:40 PM
FrinkFrog's Avatar
Send a message via AIM to FrinkFrog
As in fog?
'83SC
'76 911S - Sold.
Old 01-07-2009, 09:21 PM
Im running a single cooler right now (rear engine mount one) and my temps are super low in the cooler weather. I have to make some lines for the front cooler by summer though
'80SC ROW
'76S Wide Body
'87 G50 Coupe
'69T Bahama Yellow
Old 01-07-2009, 09:39 PM
awdbandito's Avatar
This wouldn't happen to be a blue euro SC is it? If so, I'm the guy in the white '77 carrera 3 that you've met at autocross. I can't remember your name, sorry.
Old 01-14-2009, 07:04 AM
