Porsche Junky
mede8er's Avatar
Source for upgaded electrical connectors???
The stuff you get at AutoZone is cheap....where can I find a more professional grade connector like the rubber insulated copper bits that were OEM????
1986 930 RUF equipped
Old 01-18-2009, 07:14 AM
sudo apt-get purge 930
equality72521's Avatar
http://eagleday.stores.yahoo.net/elparandtool.html
--clutch-monkey
Old 01-18-2009, 07:16 AM
Porsche Junky
mede8er's Avatar
Now thats what I'm talkin bout...Thanks Mark....
Old 01-18-2009, 09:39 AM
Amazing, thanks for posting the link!!
Old 01-18-2009, 05:11 PM
Czar of C.R.A.P.
dfink's Avatar
If you don't need a factory connector but want something decent go to your local Harley Davidson dealer. They should have Deutsch connectors in stock. Very nice multi pin connectors with reasonable prices. They have weather resistant seals and snap togeather.
Anyhow another option...
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 01-18-2009, 07:23 PM
Are the Amp Junior Timer connectors compatible with the 2- and 3-wire Bosch connectors that Porsche uses in the wiring harnesses? The housings and terminals sure do look the same ...
Brian
Old 01-19-2009, 08:54 AM
Brian
Let me check my receipt when I get home and I'll tell you which part numbers work. I built a new engine harness using the terminals from Eagle Day.
--clutch-monkey
Old 01-19-2009, 10:01 AM
Here are the connectors I used. They didn't have the round two prong connectors in the black housing though. My car doesn't use them so it was no big deal.
--clutch-monkey
Old 01-26-2009, 03:25 PM
