juicersr's Avatar
Best paint long term for fan shroud? Krylon? Plastikote?
In the middle of rebuild and just was wondering if you guys that have redone your fan shrouds could tell me your long term results. Those of u that used Krylon Fusion or Plastikote as mentioned in other threads, have u been happy with results. Anything better out there? Thanks
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 01-21-2009, 08:09 AM
Plavan's Avatar
Get it powder coated like my two engines.... You will thank yourself later.
#2 2.5L (Black)
#1 2.5L (Silver)
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 01-21-2009, 08:53 AM
Head416's Avatar
Isn't the shroud the piece that is missing from the above pictures?
Aaron
'81 911SC RoW Targa
Old 01-21-2009, 10:46 AM
Plavan's Avatar
What??? you can't see I painted my shroud with Krylon "Clear"
LOL... I was thinking the fan housing piece around the actual fan.... My bad.
I think I just used regular Krylon on mine. Worked out just fine.
Chad Plavan
Old 01-21-2009, 10:52 AM
I get the best puff can finish from plastikote engine enamel. That has been my experience for over 15 years now and I have alot of experience with air pressure spray guns.
First warm the part in the sun, under lamps, or with a heat gun but only get them warm not hot because that will boil off the solvents too fast and make bubbles in the paint.
The first coat should be a light tack coat that doesn't completely cover so the second coat sticks and doesn't fisheye. The nice thing about plastikote 500 degree engine enamel is you can spray on very wet 2nd and 3rd coats in approximately 20 minute intervals and it won't blush, wrinkle, or fisheye at all in my experience. Other puff can paints will...
It comes out a very smooth thick durable paint finish that looks alot like urethane enamel when dry.
It takes several days to fully dry and I try to leave parts sprayed with it in the hot sun after about 6 hours of air drying time.
If you want a more durable satin finish puff can paint that doesn't flow out as smooth and glossy as the plastikote engine enamel when spraying heavy wet coats but is tougher, then russel epoxy puff can spray paint marketed for painting motorcycle frames works very well.
Old 01-21-2009, 11:20 AM
juicersr's Avatar
Sorry guys, i meant the fiberglass 'Engine' Shroud. My bad.
dzugautomobili.com
Old 01-21-2009, 12:00 PM
I used Dupont Imron without any primer.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-21-2009, 12:32 PM
jwetering's Avatar
I had mine lightly sand blasted and then I painted it with Krylon red (actually the Canadian equivalent). Looked like stock, only a bit better (brighter). No issue whatsoever. Looked good, stood up very well.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 01-21-2009, 12:40 PM
Slippery Slope Victim
NY65912's Avatar
Krylon makes a plastic/fiberglass paint. "Sundried Tomato" is the color I used on my 3.8 and it seems to have held up very well.
I then shot a thin coat of semi-gloss clear.
It's not too glossy but i think it looks nice.
I think I have a full can left if you are interested.
Mike˛
1985 M491
Old 01-21-2009, 12:55 PM
Free minder
Aurel's Avatar
+1 for Krylon. I used it and i like it.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 01-21-2009, 04:23 PM
Don't forget to replace your fan/alternator nut, Mike...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 01-21-2009, 05:12 PM
juicersr's Avatar
Thanks guys. Does it just go by 'Krylon fiberglass paint?' Do u use a standard primer?
Wow Mike, that is one sweet engine!!... what did u guys finally manager to get out of her with dyno tweaking?
dzugautomobili.com
Old 01-21-2009, 05:25 PM
Free minder
Aurel's Avatar
I used Krylon Fusion for Plastics, without primer since it is formulated to stick to plastics.
Old 01-21-2009, 05:46 PM
juicersr's Avatar
Thanks Aurel
dzugautomobili.com
Old 01-21-2009, 05:53 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Anyone know the correct "matching" color for the green shrouds (2.7S engine)? I like the green (it's bizarre) but it looks a tad beat up - I just left it raw fiberglass for now but if I can spray it with something I will.
Black Cars Matter
Old 01-21-2009, 05:56 PM
87 Carerra, 3.2 liter en
Can someone please tell me what is the best way to paint or upkeep the actual fan. I first buffed it out and that was no good because it kept tarnishing. I then had it clear coated but even that tarnished. So, I am going to strip that off. What has everyone had luck with on a long term basis
Sorry for highjacking the thread but I thought it was really closely related
Old 01-21-2009, 08:15 PM
juicersr's Avatar
No worries, i had the same problem for years before i threw in the towel and just started powdercoating all my fans. I know not stock, but Tom Butler (tom1394racing) did a nice job powerdercoating his to an 'RSR' style finish.
If you find the right powdercoater, he could probably match just about any color u want.
dzugautomobili.com
Old 01-21-2009, 08:39 PM
NY65912's Avatar
Yep, it was Krylon "Fusion".
We got 360+ hp at the wheels which with 15% loss should be at 415 ish hp at the flywheel.
Tom Butler's fan finish is a secret formula used by Auto Associates and duplicates the true fan finish.
I bead blasted my fan and clearcoating them only, if and when it needs to be refinished it will be an easy job of re-clearing.
I did however clear powder coat the fan on my 3.2 M491 and it has held up very well.
That pic was taken during the build, the fan nut was installed
A few years ago I did some experimenting but to no avail on duplicating the original finish. One day when I have time I'll get back to it.
See this link: http://www.krylon.com/products/fusion_for_plastic/
The finished product.
Mike˛
1985 M491
Old 01-22-2009, 04:03 AM
juicersr's Avatar
Holy smokes Mike, those are fantastic numbers!
Thanks for the details on the Krylon, gonna get some today (thanks for the offer on the can Mike, but i've got two shrouds to do)
U guys are great.
dzugautomobili.com
Old 01-22-2009, 06:05 AM
Less brakes, more gas!
euro911sc's Avatar
Here is the same question answered over in the engine rebuilding forum. Essentially, you use Krylon Fusion or a professional auto paint to get the best results.
Engine Shroud Painting, Help!
Enjoy!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 01-22-2009, 06:51 AM
