Is there any reasion I can not test the AFM in place with the key on or using the 9 v battery approach?
Old 02-13-2009, 09:42 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I believe you can, Rusnak did that exact thing but it is alot easier with the AFM removed and omn the bench.
'85 Carrera Targa
PCA/POC
Old 02-13-2009, 11:52 AM
Draco, when you say loosened 4 clicks, do you mean you adjusted the 'clock spring' to change the resistance against the barn door?
Old 03-09-2009, 01:57 PM
DRACO A5OG's Avatar
Yes! But I recommend you hook up a LM1 to icheck/nsure proper AFR.
'85 Carrera Targa
PCA/POC
Old 03-09-2009, 09:31 PM
crashr's Avatar
I seem to have the exact same problem but I tested the AFM and it swept evenly across the range when hooked up to a 9V battery. I don't know what else can cause a rich running mixture.
Dennis
1975 Widebody 911 3.2 Euro
Old 07-13-2011, 02:02 PM
DRACO A5OG's Avatar
I am suspecting my Fuel Pressure Regulator. waiting on Doyle to examine his after swap out. Stay tuned or my BG44K thread.
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 02:06 PM
dshepp806's Avatar
Interesting thread,..adjusting that spring tension in the AFM is "serious" business.....but it sounds like the instrumentation was inplace to meter! Good news!
I've still NOT installed the part yet, but am trying to arrange the schedule to get some time,..(shouldn't take THAT long just for the part changeout). I don't have my gauges to get the pressure readings post install-even pre-install although my Wrench said they were spec after the fuel pump changeout.
You know, even after the changeout, it may be "prudent" for me to keep the original around, just in case, in perfect working order,..once I'm comfortable with the fresh Bosch piece,..THEN, I'll cut that MOTHER apart and see what a ~23 year old diaphragm looks like?
I WILL get to it, DRACO.
Hoping to autopsy the oil and fuel filters (post BG44K) on Saturday...Rusnak is "interested" in my insolubles,..so, let's go look for such matter, no?
Best to you!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-13-2011, 02:43 PM
dshepp806's Avatar
I recall reading (long ago) that some piece of the AFM calibration (factory) involved use of laser...anyone know (or have heard of) this?
Best!
Doyle
Middle Georgia
Old 07-13-2011, 02:45 PM
DRACO A5OG's Avatar
I was told they were individually calibrated at the factory. Not sure how though.
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 02:48 PM
Yeah, I don't think I'd touch the clock spring. That's what you buy a MoTec for.
I have to go back to source material to re-think Crashr's question. I also should check my own fuel pressure with and without the fpr connected for comparison.
Old 07-13-2011, 02:55 PM
DRACO A5OG's Avatar
I have a spare AFM, while driving around to zero in the mapping on my chip, Steve W and I messed with the spring to fine tune her. It worked fine but I was insecure so swapped back to my known good AFM.
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 03:00 PM
when one has an eprom and a dyno, one messes with the clock spring with impunity, lol.
Old 07-13-2011, 03:02 PM
DRACO A5OG's Avatar
, well I got the LM-2 now, all vacuum leaks found and fixed. Once I can verify the state of the FPR, will be re-tuning
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 03:07 PM
Oh, you sick-o!!!! ....so, how do you like it? Is it awesome? lol :::jealous:::
Old 07-13-2011, 03:15 PM
DRACO A5OG's Avatar
It is pretty awesome, especially with the RPM reader and SD card to capture the data.
It is here for my buddy's, so when you in town stop by and we can see what she is doing
Always felt bad bothering Steve W, everytime I want to check my AFR. He is so busy and gracious with his time. Well I told him he has a back up if he every needs it
'85 Carrera Targa
PCA/POC
Old 07-13-2011, 03:18 PM
I never did get the software working for my LM-1. I sorta wing it with the computer in my lap all the way up to max rpm. You need a chip burner now, brotha!!!
Old 07-13-2011, 03:56 PM
