3.2 rpm signal
Is there an RPM signel wire in the:
Motor compartment, or
At the ECU?
Thank you.
Old 01-23-2009, 02:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Well as I recall from the Reference Sensor it goes into the ECU/DME (terminals 25 & 26 per Bentley)and back of the Tach in the Dash.
'85 Carrera Targa
PCA/POC
Old 01-23-2009, 03:01 PM
So there may only be an RPM signal going from the ecu to the tachometer.
No signal in the motor compartment?
Nothing off the coil? (Sorry if that is a dumb question.)
Somthing like what would be needed for an addational injector driver.
Old 01-23-2009, 03:29 PM
Zeke's Avatar
flywheel sensor.
Old 01-23-2009, 04:57 PM
