3.2 rpm signal
Is there an RPM signel wire in the:
Motor compartment, or At the ECU? Thank you. |
Member 911 Anonymous
Well as I recall from the Reference Sensor it goes into the ECU/DME (terminals 25 & 26 per Bentley)and back of the Tach in the Dash.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
So there may only be an RPM signal going from the ecu to the tachometer.
No signal in the motor compartment? Nothing off the coil? (Sorry if that is a dumb question.) Somthing like what would be needed for an addational injector driver. |
flywheel sensor.
