moneymanager's Avatar
Separating Bilstein insert from front Boge strut
I've pulled Bilstein inserts out of Bilstein struts before but the front Boge struts (car was a 74) seem to lack the pin one is accustomed to driving out. Pull the hat off and unscrew the big collar with two notches on it? I assume a hammer and an appropriate scrap of steel could be used in lieu of a special $200 spanner? Thanks,
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 01-23-2009, 12:27 PM
Zeke's Avatar
If you don't care about leaving marks many have used a large pipe wrench or super size channel lock pliers.
Old 01-23-2009, 01:10 PM
Friend of Warren
+1 to the pipe wrench.
Kurt V
Old 01-23-2009, 01:44 PM
I don't think I even left noticable marks on mine when using a pipe wrench, and I'm picky about stuff like that.
Old 01-23-2009, 02:48 PM
KTL KTL is offline
Schleprock
KTL's Avatar
If it's on there tight, pipe wrench will more often than not leave marks. Actually two pipe wrenches are perfect for this job. Even if it does leave marks, you'll still be impressed how well the pipe wrenches work for removal. Fuhgetabout using a spanner to remove, that's just asking for bloody knuckles and some expletives! Pipe wrench(es) make cake of this job.
Kevin L
'86 Carrera "Larry"
Old 01-23-2009, 02:54 PM
Ok, I'll try the pipe wrench. Thanks to all.
jhtaylor
santa barbara
Old 01-23-2009, 03:45 PM
911ctS's Avatar
Send a message via Yahoo to 911ctS
I have the proper spanner wrench and have had to repair it multiple times since it is weak. So when the gland nuts are on their tight I reach for the trusty pipe wrench.
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 01-23-2009, 03:58 PM
bilstein will send you the tool, if you have time to wait.
206 637 4071
Old 01-23-2009, 04:03 PM
I will sleep much better now knowing that I am not alone in applying a pipe wrench to my Bilstein inserts.
jhtaylor
santa barbara
Old 01-23-2009, 04:24 PM
175K911's Avatar
I painted my pipe wrench "Bilstein green" so I can feel better about using it. But frankly I can't imagine doing it any other way.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-24-2009, 04:45 AM
