JMAN718's Avatar
83 911sc just started to run slightly rough.
My 83 sc recently started to run slightly rough. I change the cap and rotor, but still running slightly rough. There is a valve gasket leaking oil, would that cause any vacuum leaks? I don't drive my car as a daily driver anymore. But I have it service every 6 month (minor service). Could it need a valve adjustment? It does not sound like the valves are making a different kind of noise? Any suggestions?
Thank you, JMAN
Old 01-24-2009, 06:01 PM
Ruby911
ruby911's Avatar
rough at idle or all the time?
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 01-25-2009, 08:26 AM
JMAN718's Avatar
It idle slightly rough, and as I drive it feel as if the engine is running on 5 cylinders. I notice at idle it smells sort of rich?
Old 01-25-2009, 01:24 PM
JMAN,
It just may be telling you that you need to drive it more. Or that the temps have dropped and you have a lean condition during warmup. Valve cover gasket will not cause a vacuum leak, but they are plently of potential leaks on old CIS, injector sleeves, o rings, boots, hoses, the best way to find them is with a propane torch. My suggestion would be to pull the spark plugs and take a look at them, clean and gap if OK, check wire ends, fire it up, run it until hot +10 miles, then hook up a analog dwell meter to the test plug and the CIS lambda will tell you what is going on. Much better than smelling rich, which is out of fashion lately. If you have a cold start stumble, my first recommendation is to disconnect the vacuum retard and reset the timing to 5 BTDC @ 950 rpm and the mixture to 30-40 dwell, this usually give the best cold start performance. If you still have a problem, you need to check the cold and warm control pressure and the system pressure.
Paul
Old 01-25-2009, 02:02 PM
Ruby911
ruby911's Avatar
Mine started running rough - mostly at idle, but also a little under acceleration. RPMs were down at idle as well. I ended up discovering an oil breather hose that was split. Fixing that fixed the rough running problem.
1965 356C Outlaw
RGruppe #577
Old 01-25-2009, 02:27 PM
JMAN718's Avatar
Thanks guys for the information, could you tell me where to look for that oil breather hose? Thanks...
Old 01-25-2009, 04:40 PM
Ruby911
ruby911's Avatar
Look behind the oil filler neck on the right side of the engine bay. There are two hoses about 1inch in diameter that are attached to the oil tank there and route back behind the engine. One can be replaced without too much trouble, the other will require at least a partial engine drop to get to. I did a temporary patch with parts from Home Depot until the new hoses arrived from our host. Now, it is a matter finding the time to partially drop the engine and install the hoses (they arrived this week). If this is your problem, good luck with it.
1965 356C Outlaw
RGruppe #577
Old 01-25-2009, 05:37 PM
EMT/TechRescue Instructor
86911cab's Avatar
Sounds like the symptoms I had. The RPM's should drop slightly when you remove the oil filler cap, no change could be an indication of a vacuum leak. I found 2 intake gaskets leaking.
My symptoms were: Popping exhaust, rought idle, no idle change when oil cap was removed, could not adjust Idle with idle screw.
Good Luck!
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 01-25-2009, 09:36 PM
T77911S's Avatar
plugs?
did it backfire? popoff valve installed or not closed properly? i found the pin sliding out on mine and have heard of others looking like they are closed but are not
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-26-2009, 06:36 AM
lonewolf's Avatar
fuel filter
Old 01-26-2009, 07:09 AM
