H4 Fitment ?
I have a 71 Targa and have been searching for H4's to fit into my buckets. Will any H4's work, will some of them not work.. If so which, or what will I need to find for correct fitment? part #'s could help.?
Ive come across some from a 74... ??? Is the relay necessary? If so, whats the wiring schematic for it? Thanks!
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
relays are recommended for all 911s, but are really desireable for those using high wattage H1 or H4 bulbs, the stock headlights were something like 55watts, i've seen up to 100watt H4s used on the stock circuit, all the currect goes thru the steering column switch which will have a limited life expectancy. wiring diagrams have been posted a # of times, try a search.
For clarification the H4's Im referring to are the entire assemblies. The "slant back" style lamps.
If using 55 watt bulbs is the relay necessary or only if using higher wattage? Thanks
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
THe US and RoW headlights prior to the intro of the H5 bulbs were freeely interchangeable. The factory felt ok w/o relays on the 55 watt bulbs. I wouldn't
So then, any slant style H4 pre 80's is safe to say will bolt up and the electricals will work as well. Consider adding the relay with 55watts.
I heard that there was some sort of vacuum something or other.. really not sure about that.. are you familiar?
