Senior Member
Superman's Avatar
SC - Carrera Sway Bar Specs
I'm confused.
I believe the sway bar sizes went from 20/18 (F/R) to 22/21 in 1896. In other words, they were 20/18 in 1985, and then 22/21 in 1986. Correct?
Then, the next year, the G-50 transmission came out. Did these cars (with the G-50) have a different kind of sway bar?
I am trying to upgrade a 1978 SC. I have been told that Carrera sways will work well, and I wonder what model year(s) of Carreras to look for.
Mocha 1978 911SC. "Coco"
Old 02-05-2009, 09:31 AM
Work in Progress
Rich76_911s's Avatar
Yes they did change in 1986 to thicker bars.
For the upgrade ideally you would want '86 bars, but the later G-50 bars will also work. The only difference is that the G-50 rear sway bar will hang lower to get around the bigger G-50 transmission. If I recall correctly Noah did this to his car and he loved it. I have '86 bars for my car, but I've never driven my car.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 02-05-2009, 09:54 AM
You ask about sway bars but give specs on torsion bars ...... Which is it?
crude rudy
'84 cab
'14 ZX-14R
Old 02-05-2009, 09:56 AM
Senior Member
Superman's Avatar
Nope, those are sway bar diameters in millimeters.
Old 02-05-2009, 09:58 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
All '86-'89 22/21mm sway bars work, great upgrade for street & occasional track.
FWIW- on my street car I am still running the original rear mounts w/ 22/21 s-bars. No issues after 8 years and occasional track use.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 02-05-2009, 10:20 AM
Senior Member
Superman's Avatar
Thanks, guys. I've sourced some '87 sways. They should work nice with my fresh shocks and 22/29 torsion bars. Woohoo!
If I break a sway bar mount, I'll fix it.
Old 02-05-2009, 10:55 AM
