| Registered Join Date: May 2008 Location: NY
				That "Wallowing" Feeling.........
			What is the single most important procedure to get rid of the "wallowy" feeling in the front end while cornering at high speed? I don't think turbo tie rods will do anything, but what about different sway bar, or torsion bar, or struts, etc. ? New tires with correct pressure helped a tiny bit, but still plenty scary under hard curves. I believe the struts are original all around and while very old (1985) there is very low miles on them. (under 60K)
				__________________ 1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc. | ||
|  01-25-2009, 09:09 AM |
| PRO Motorsports Join Date: Nov 2001 Location: Burbank, CA
			Shocks and struts. And not just the front.
				__________________ '69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 | ||
|  01-25-2009, 09:28 AM |
			It's also highly likely that you have Boges.  Converting to Bilsteins would do wonders.
|  01-25-2009, 09:31 AM |
				 | Quote:
 Are Bilstein's available as a whole replacement unit or just as inserts? How big of a PIA is it to do the inserts?
|  01-25-2009, 02:06 PM |
| Registered | Quote:
 Your 85 was a transition year for the Boge strut and there are two different part numbers for bilstein inserts for Boge struts. The Pelican catalog shows a part for "1974-3/1985" and "4/1985-1989", which I assume means the transition happened in March/April of 85. The build date of your car will be a decent guide, but if it were me I would want to find out the part numbers for the different struts and the corresponding shock part numbers. IMO, changing the front shocks is pretty easy. See Wayne's 101 projects book for guidance. | ||
|  01-25-2009, 02:32 PM |
| Registered |
			Slower, smoother steering inputs are free and worked quite well for my car ... but I make no claim to being a great driver.
				__________________ '88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" | ||
|  01-25-2009, 03:09 PM |
| Registered Join Date: Dec 1999 Location: Novato, CA
			Alignment.
|  01-26-2009, 04:32 AM |
| Registered Join Date: Jun 2006 Location: Virginia Beach
			I like the feel of that strut bar across the towers in front as well as a nice set of bilsteins.
				__________________ Rusty 71 911E 55 PreA speedster 85 Turbo look Cab 62 Twin Grille Roadster (getting close) | ||
|  01-26-2009, 01:43 PM |
| Registered Join Date: Feb 2002 Location: Chalfont Pa
			Make sure the rubber donuts where the rear torsion bars connect at springplates are  in good shape. My car felt really strange and it was those donuts. New one's and the car was transformed.
|  01-26-2009, 02:08 PM |
				 | Quote:
 I guess I will be putting new struts on and going from there.
|  01-26-2009, 03:08 PM |
| Registered Join Date: Mar 2008 Location: Seattle, WA
This. My poor '88 was wallowing like a whale on a workout until I had Mr John Walker replace the original 60k mile Boge shocks with nice fresh Bilstien HDs. Now my baby is as frisky as an Orca on RedBull.
				__________________ Carrera 3.2 - "Faster, Stronger, Better" | ||
|  01-26-2009, 03:13 PM |
| Registered Join Date: Jan 2002 Location: Long Beach CA, the sewer by the sea.
			What kind of new tires did you put on? Tires themselves are very important. Just ask Tyson about when he drove my '71 S "Ragamuffin" on Dunlop Sports.   Of course all the above suggestions are good. Bump steer, shocks, alignment, etc. | ||
|  01-26-2009, 03:50 PM |
| muck-raker Join Date: Jan 2009 Location: Coastal PNW
			I've been following this thread a little bit, trying to decipher exactly what "wallowing" is.  I've noticed that my Cabby goes great around nice, smooth corners...but jumps around a bit in less smooth corners.  I equated this with the term, "bump steer".  Are we talking about the same thing? I have BFG "G-Force Sport" tires on all fours, mounted by the PO. They look great and grip well, IMO. What's the general consensus about these tires from you experienced Porschephiles out there? (Be honest...I won't get my feelers hurt.) kidrock out.
				__________________ STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.  Deny Everything; Admit Nothing; and Always Make Counter-accusations   | ||
|  01-26-2009, 05:00 PM |
| Registered Join Date: Dec 2008 Location: San Antonio, Texas
			Turbo tie rods do make a difference but I think your problem is either shocks or tires. On a Targa I prefer the adjustable Koni gas shocks. I think the Bilsteins are a little too stiff. Plus every Bilstein I ever had tended to start making clunking noises at the top of the strut. Make sure you run the european ride heights.
				__________________ 1973 911S (since new) RS MFI specs 1991 C2 Turbo | ||
|  01-26-2009, 07:07 PM |
				 | Quote:
 The tires are brand new Dunlop Star Specs and they are fantastic, so I know its not them.
|  01-27-2009, 07:55 AM |
| Senior Member Join Date: Feb 2000 Location: Lacey, WA. USA
			There are a few guys who post here whose advice is so reliable that failing to listen to them will always be a mistake.  Tyson is one of those guys.
				__________________ Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" | ||
|  01-27-2009, 08:02 AM |
| MBruns for President |
			Tyson, John Walker, Steve Weiner, Bill Verburg, Jeff Alton, Henry Schmidt -  Take it to the bank!
				__________________ Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 | ||
|  01-27-2009, 09:15 AM |
