muck-raker
3.2 airbox replacement
tried a search on this, but no luck.
Want to replace the air box on my 3.2 with a K&N (cone style) fresh air intake. Tried to find a K&N on Pelican Parts search...no luck. Any ideas are greatly appreciated. ALSO...I've done this before on several cars, and it was pretty straightforward. I'm assuming the same for my 3.2. Am I correct, or is there anything I should pay particular attention to during removal/installation? Thanks...
It's relatively simple. MSDS makes a cold air intake, I'm not sure if our host carries them or not. I just bought a 1-off carbon fiber cold air intake and I'm thinking about using it to make a mold to make more.
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
Just realize it's mostly useful for changing intake sound. The concept of a 'cold air intake' doesn't really apply to an air cooled 911 - at speed the engine fan moves so much air through the engine compartment that it never has a chance to warm up.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
muck-raker
Never really thought about that...I've seen a lot of pix with the K&N setup and thought it was probably beneficial, and not a hindrance. I have a SW chip and MK exhaust. Anybody else think it's better just to leave the box alone and install the square K&N filter instead of replacing the box with the "cold air intake"? |
Member 911 Anonymous
I found this at Autozone RX3900, fits perfectly if you have a lid shock in the way, like mine. I have a Turbo Tail and Lid Shocks on both sides.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
See my sig for details:
1997 Boxster SOLD 1999 R1100S SOLD 1988 Carrera 3.2 |
3.4 Bigger is better
No performance benefit with the K&N. There have been posts with dyno numbers showing no hp increase. If you do a search there is a lot of info.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
^ That's a different way to route your plug wires, I like it.
'84 911, some sort of red color '05 Subaru WRX wagon |
Like this?
Ruf, the plug wires routing over the shroud is indeed stock, but I deviated just a bit after removing the A/C compressor and also changed the routing a bit over on the left side too (heater backdate):
muck-raker
OK. From all the input I have, I have come to the following conclusions...your input is welcome.
1) it will not hurt the 3.2 if a K&N intake is installed (like the pic above by Ruf), although there is no real increase in hp. 2) cutting the original airbox may be a better solution, mostly for the purpose of easier access. A couple of you stated that such mods will change the sound, but little else. Would I be correct in saying that such a sound is due to an increase of air intake? And would that cause a "lean" condition? Also...for the "Purists"...do you believe the removal or modification of the airbox takes away from the overall "originality".
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
The sound does not change because of a change in flow. The intake system has inherent operating sound just like the exhaust system, albeit a bit less of it. The stock airbox acts as a muffler for this intake noise. Cutting holes in it or replacing it with a cone filter simply lets more of the intake system sound get out, thus changing the way the engine sounds.
And it is my opinion (and no more) that a K&N does not filter as well as a stock paper filter, so if you drive in dusty conditions, that may or may not be a consideration. Hold a K&N up to the light, and hold a paper filter up to the light. At least for the K&N that came with my car, I could see lots of tiny dots of light through the filter. Not so for the paper filter.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" Last edited by burgermeister; 01-26-2009 at 01:19 PM.. |
Jupiter 911
Kidrock, I just recieved my MSDS air intake on saturday, I had searched high and low. Its well made,the fit is perfect and the cost for my 87 3.2 was $132. See pic.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
they allow dirt to pass through that a paper element would catch, so why would you want one? just for the coolness factor?
abides.
In the commercial world, the only place you'll see K&N filters is in the engine room of marine pleasurecraft.
Not much dust down there, and the owners love the bling factor. ![]() Look at any serious engine and you'll find a paper filter.
Graham 1984 Carrera Targa |
When Steve Wong sent me my chip, he said the stock airbox was the way to go. My tech told me the same thing. I had the MSDS and traded it for a stock box. No loss of performance just different sound. I swiss cheezed my cover for fun.
The premuff and chip were the real performance tweak.
------- Glenn 86 3.2 Blk/Tan Wong'd Whale Coupe, Dansk Pre, Monty |
Recreational User
Material Safety Data Sheet?
Its a K&N filter that is sold under MSDS label as a Motorsports product line owned by K&N. Sounded good in my Carrera and saved lots of room. Consensus was that the OEM design was superior so bbye.
