I was dressed down once while warming up a rental car in the winter. |
+1 on what the German boys wrote in my 89 owners manual,..get to driving (lightly) soon after cranking her up.....no long term idling. 20-30 minutes of idling? no frikin' way. I can get the cabin heat up MUCH quicker when I'm driving her,..it doesn't take long at all. My regiment is much like Spuggy's. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
different strokes for different folks
during cold winters I start and keep rpms as low as possible till the 90-100#'s low rpms oil psi starts to come down. I also start with clutch engaged so I'm not loading engine thrust bearing without oil psi. Swepco is not an issue at 20F doing this. Then I raise rpms till cylinder head temps [CHT] raises to 175F degrees. Manual throttle is a great install. If at a warm idle I'll raise rpms to 1,200-1,500 to keep alternator and cam lubrication ok. The act of glazing cold start spark plug carbon is a consideration with carbs. Don't whack the throttle when cold, gently raise rpms. FI is more forgiving.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Alter Ego Racing
Perhaps worst of all is you commit the typical mistake of warming up the engine and taking off like a bat out of hell when the rest of your drivetrain is " cold".
A lot of us think about bringing the engine up to temp but never think twice about the tranny for example.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
AutoBahned
The advice -- given by the engineers who created the car -- is based on the simple fact that the 911 motor will take almost forever to warm up at idle, not to mention the damage from idling a cold motor. That does not mean that you cannot get away with it. But if you are buying a used 911, try to avoid buying one from a guy who does this sort of thing to his car. |
I'm kind of between the rock & the hard spot on this subject.
Mine is an AX only car, not street legal and putting around on slicks (not R specs)on access roads is a good way to get flat....those are usually crudier than city streets. There are no "warm up laps" at AX. I have sat in the car idling with a blips, elevated revs, yada.....this takes about 10 minutes just to get the temp gauge off the peg (50C), much less to operating temp. I have tried throwing a towel over the air intake grill...leaving some space for air flow..... and this seems to work most quickly....but doing this seems wrong somehow. Probably not as wrong as beating on a cold engine, tho. Comments?
JPIII Early Boxster |
How much do they weigh? ![]() A portable one would seem impractical in the staging lanes....not to mention the ribbing I would get....but I'll think on it.
