Front rotor question
Guys:
Had cross drilled and slotted rotors on the car (914-6) and discoverd one cracked. Bought used as part of a package so not really sure what they are and neither is seller. Using with big Wilwoods. Picked up a set without drilling (ATEs with fancy pattern) but a significant dimension difference that has me puzzled. Both old and new are 11' (plus a tick) in diameter. Old ones are about 15/16" thick, while new ones are closer to 3/4" thick. Anyone able to tell me what rotors are thicker or guidance as to how much difference. Believe new ones are an SC part. Having to respace calipers and somewhat concerned over piston projection. Thanks , TOT
TOT |
What's Facebook?
Carrera rotors are slightly thicker that SC rotors. My guess is that you have one of each.
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
911 '84 - 89 are 24x290mm
Rotors
Thanks guys ...Mystery solved.
TOT
TOT |
