Front rotor question
Guys:
Had cross drilled and slotted rotors on the car (914-6) and discoverd one cracked.
Bought used as part of a package so not really sure what they are and neither is seller. Using with big Wilwoods.
Picked up a set without drilling (ATEs with fancy pattern) but a significant dimension difference that has me puzzled.
Both old and new are 11' (plus a tick) in diameter. Old ones are about 15/16" thick, while new ones are closer to 3/4" thick. Anyone able to tell me what rotors are thicker or guidance as to how much difference. Believe new ones are an SC part.
Having to respace calipers and somewhat concerned over piston projection.
Thanks ,
TOT
TOT
Old 02-01-2009, 07:59 AM
What's Facebook?
turborat's Avatar
Carrera rotors are slightly thicker that SC rotors. My guess is that you have one of each.
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 02-01-2009, 08:05 AM
Bill Verburg's Avatar
Originally Posted by zztot View Post
Guys:
Thanks ,
TOT
911 '69 -'83 are 20x290mm
911 '84 - 89 are 24x290mm
Bill Verburg
Old 02-01-2009, 08:07 AM
Rotors
Thanks guys ...Mystery solved.
TOT
TOT
Old 02-01-2009, 07:51 PM
