Do I need an O2 sensor on my 86 Carrera?
Looking for opinions on whether or not I need an O2 sensor on my 86 Carrera.
I've added a Steve Wong chip, European Racing Headers into dual SuperTrapps. Car run great. Question is though would it run better if I were to reconnect the O2 sensor? Appreciate the feedback
86 Carrera POC Racecar 07 Cayman S 13 Tacoma TRD Sport 16 VW Sportwagen |
Did it have an O2 sensor hooked up at one time? Is the SW chip programmed for an O2 sensor?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
abit off center
If the sensor is working correct then just leave it, if not, like in mine, I took it out and had SW tweak the chip without it.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
How will you smog it?
grateful user
02
your 02 is the tattle tale of your complete fuel injection sytem on a motronic car. your carrara has a throttle swich that puts 02 into open loop (N0 02 feedback) when giving it the gas, so it has no effect on wot performance, but it will make your car get A LOT better fuel mileage, run cleaner, and your motor will LAST longer. why do you want to dissable it?
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
+1 on what don gilbert said. There are more reasons to keep the sensor than not. IF your car was an SC that would be a different story. The car will idle much smoother with the 02 as well.
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... Last edited by dimeified; 02-06-2009 at 06:29 AM.. |
SCWDP- Shock and Awe Dept
It's a track car and you have a SW chip. Not knowing what the chip was programed for, unhooked is the safe option. SW is the only one that can really say if it should be hooked up or not.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
abit off center
