correct rev limiting rotor
My 2.2 T engine has been modified with:
Original T crank S pistons & cylinders mildly ported T heads E cam What would be a suitable rev limiting rotor? 6800, 7000, or what? Thanks in advance, Robo
356robo 70 T Targa Looking for a 2.2,2.4, or 89 coupe |
I used to have a 2.4T with E cams, and I used a rev limiter rotor from a 914-4, as it came in right a 6k, (which is funny, because the 914 redlined at 5.5K)and left no risk of any possible engine damage, and the car pulled strong right up to 6k.
You have a non counter weighted crank, and I assume you are still using stock valve springs? If so, I don't think I'd use the 7k limiter,With the 2.2 crank and springs.
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
