3.2L engine identifiers?
I'm in the process of buying an engine reportedly out of a 1987 911. The only numbers i have is off of the head #930.105.111 and the intake #911.110.1692r.
The slanted intake is on top facing the fan etc., my question is where can you find the block numbers or other identifiers on the engine. Not sure if it isn't actually an early model 3.2L or maybe a 3.0L engine. thank you Roy |
if you can post a picture we can tell you immediately what it is.
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... |
I don't have the engine here, the only photos i have are on ebay under item #170302287028. thanks for helping Roy
Certified Pre-Owned
Nope. 3.0 CIS motor pre-'83 there. And I wouldn't touch it with a 10 foot pole off eBay with such little information.
'84 Carrera Coupe |
to the right of the fan, behind the oil pressure sender:
930/21 lower compression North America/Japan 3.2 motor 84-86 930/25 lower compression North America/Japan 3.2 motor 87-89 930/20 and 930/26 higher compression ROW 3.2 motor
