-   -   Tough question on stripped threads (http://forums.pelicanparts.com/porsche-911-technical-forum/457861-tough-question-stripped-threads.html)
cl8ton 02-17-2009 09:38 AM
All I seemed to have stripped some engine mount threads described in this post;
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/457782-stripped-rear-motor-mount-threads.html
I would really appreciate if anyone here could take a look and advise!
Peter Zimmermann 02-17-2009 11:09 AM
A Time-Sert should be OK if you use one with the correct depth, and there is sufficient material to hold the insert. A Heli-coil is also an option to consider. The torque spec for those bolts/studs is 35 lb/ft, so check with a local machine shop about each type of insert and what they prefer. Each insert requires a tool set for installation.
