-   -   The engine doesn't want to go in! (engine install) (http://forums.pelicanparts.com/porsche-911-technical-forum/457868-engine-doesnt-want-go-engine-install.html)
JohnJL 02-17-2009 06:22 PM
I've done it both ways but at this point, if you are having problems you really are better off dropping the transmission to. Its just two more bolts, speedo and the reverse light plug. Quit struggling with it and try this approach.
Gogar 02-18-2009 10:36 AM
You forgot about the CV joints, but I agree with you.
Ricks911s 02-18-2009 04:05 PM
Looks like in the next few days I'll be taking out the trans. Guess it's something else to learn how to do on the Porsche. Cool (sort of).
Carrerax 02-18-2009 05:06 PM
Good idea, Not to mention a good time to clean up the box, replace the oil and inspect the axles :)
Gogar 02-18-2009 05:18 PM
Since you're gonna . . . . . . :D
Make sure you replace your shift rod seal and input shaft seal. Cheap and easy.
Ricks911s 02-18-2009 05:19 PM
Oh man, I hear the words "while you're in there" chiming down from the Porsche Gods already.
Come on guys. I'm a young guy and on a budget!
Carrerax 02-18-2009 05:33 PM
The only extra stuff is cheap, Oil and a few very cheap seals. Money well spent.....and not much to boot.
mede8er 02-18-2009 05:51 PM
Those aren't allens...get a CV joint tool...
JohnJL 02-18-2009 06:20 PM
I'm not sure you absolutely need to remove the axles. If you are just looking to drop it down slightly so you can align and mate it to the engine you might be able to get away with putting a jack under it and sliding it backwards/down slightly. A free "while you are in there" is to check the tightness of your CV bolts.
Ricks911s 02-18-2009 06:26 PM
Do you mean there is an appropriate torque value for the CV bolts? I haven't messed with them before.
Ricks911s 02-19-2009 09:51 AM
Confirm parts
Do you mean parts 999-113-327-40-M30 and 999-113-185-40-M30?
deanp 02-19-2009 10:37 AM
"Is the clutch fork engaged properly when mating the tranny?"
+1
If the clutch fork is not engaging properly on the throw-out bearing, the input shaft will slide through the pressure plate and into the pilot bearing, but you'll end up with the clearance issue you are talking about ... 1". The clutch fork needs to be rotated slightly to clear the rearmost section of the throw-out bearing and then allow the other flange of the bearing to rotate it into position for operation.
Get everything lined up and square, then look through the gap between the bellhousing and motor with a flashlight, align the clutch fork properly and slide the motor back.
deanp 02-19-2009 10:41 AM
Like this -
http://forums.pelicanparts.com/uploa...1235068861.jpg
Ricks911s 02-19-2009 10:49 AM
deanp
let me clarify. we can't even get the engine close enough to the trans to have this problem. on the back (fan shroud side) there is not enough room to manuver to successfully mate into the trans side. Literally to get enough clearance (and then, there's still not enough) the engine starter bolt on the engine has to go inside the trans to clear enough room for the fan shoad. Does that make sense?
It's hard to explain. But I hope that makes sense.
felixcontour 02-19-2009 10:54 AM
Originally Posted by deanp (Post 4495608)
Like this - [/img]
OK, let's take a step back real quick.
The problem Rick and I are having (I'm helping him on the install) is NOT a clutch fork alignment problem.
The engine does not even have enough clearance to mate up properly with the main shaft coming out of the transmission. We are not even at the point where the clutch fork could interfere with the installation yet. We are still too far away.
The actual issue is that with no clearance for the fan at the rear lip of the engine bay, the pilot bearing gets hung up under the main shaft on the transmission. We can't move the engine back more to lift it up and get the shaft in. It's just hopelessly stuck.
Thus, we moved the engine and transmission up and down in various combinations, but no luck. We always got hung up under the main shaft with the pilot bearing contacting it.
I hope this clarifies the issue. I wish we had taken a picture of the pilot bearing as it was. I think we'll have to drop the transmission to fix this issue.
dshepp806 02-20-2009 02:25 PM
PICS!!!
Doyle
Carrerax 02-20-2009 02:47 PM
Drop the tranny and go from there.......
sailchef 02-20-2009 04:55 PM
How about just removing the Fan assembly? Just a thought.
Ricks911s 02-20-2009 05:53 PM
So the shift coupler is pressed up pretty good to the top of the tunnel. Working off my bberry and don't have a camera. But I think this is part of my problem.
Ricks911s 02-20-2009 06:42 PM
Okay. Sorry to make this thread like twitter . . . but I need advice.
Since the coupler doesn't appear to be disconnect it, do I disconnect it now with the engine out? Could that bend the shift rod?
I'm searching for my camera . . .
