KR8 KR8 is offline
Sorry Guys, it sounds like your getting some good advise. I will not be able to make it this weekend. Please take pics so I have a better idea what I face soon with my project.
Old 02-20-2009, 07:39 PM
1980 911 SC
Disconnecting the shift rod coupler (inside the cabin in the tunnel in front of the rear seat)should have been done way before you began removing the engine (with or without the tranny). Raising and lowering the transmission during removal could bend the shift rod, put stress on the tranny input shaft and screw with the actual coupler itself.
Life's a Beach
Old 02-21-2009, 05:20 AM
resident samsquamch
sand_man's Avatar
Agreed...
-jeff
Old 02-21-2009, 08:45 AM
I had the exact difficulty you are encountering whilst installing the motor and I did have the shift coupler disconnected.I had the motor on a atv jack and rear of the car raised with 2x4 at rear of floor pan with air jack under 2x4(floor jack would've worked).Some one mentioned earlier in the thread about also raising the front of the car to level it and I am wondering if that might have helped but I did not think of it but any way I was on my own with no help and it was getting dark on my driveway and how i eventually got it started as I remember involved raising/lowering rear of car whilst sliding motor in and out to work through the clearance issue at the starter bolt whilst at the same time obtaining clearance for top of fan shroud under the rear cross member.This involved a combination of all of the preceeding plus maybe a bit of tilting of the motor all at the same time and not forgetting to keep an eye on the clutch release fork angle to correctly engage the throw out bearing and do all of these simultaneously(on my own in the dark)It was sweeeet when it slid on there and put the mount bolts in.I decided next time the motor and tranny are both coming out/in together.
Keith
72 911 2.4T W/2.2 S pistons,webers,SSI.
66 912 Gulf Blue with Red Interior original.
Old 02-21-2009, 12:09 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
Originally Posted by carrera turbo View Post
have you disconnected the shift coupler inside the car to allow the tranny to drop far enough.i install these motors by myself and have never removed fan to install. you have missed a step on removal of the 2.7?
ed
Originally Posted by Ricks911s View Post
Yes, engine was connected to tranny prior to installing (the old 2.7 motor).
Yes, the fan shroud does hit the rear crossmember.
Ed, yes I disconnected the coupler.
It's the issue of having enough room on both sides (tranny side and fan shroud side).
ricks911
you stated early in the thread the coupler was disconnected, if its not this is your problem.
before you just uncouple it scrib or mark as needed to help udjustment when you rehook coupler, will save you a fair bit of time.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-21-2009, 12:24 PM
Looks like the shift coupler is disconnected. It slid off easily, so I don't think there was significant damage done. (as seen below).
I'm going to pull the trans today, if I can figure it all out how to do it safely. Trans mounts appear bent.
Old 02-21-2009, 12:41 PM
kristan's Avatar
Rick,
remove the tranny and check the shift rod with a straight edge.
The hole in the transmission tunnel of my car had the same bent (egglike)
appearance as yours. Actually mine was worse.
Of course the rod was bent and the seal was leaking from a previous engine removal
(not mine).
I keep my fingers crossed.
Christian
Old 02-21-2009, 01:21 PM
speedo cable?
does this look like the speedo cable for the 76 915 tranny? on the pass side tranny
Old 02-21-2009, 01:57 PM
Wer bremst verliert
JohnJL's Avatar
Yep.
Removing your sway bar can help with access too.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-21-2009, 02:51 PM
Porsche Junky
mede8er's Avatar
Follow that wire towards the tunnel...theres a connector in there you need to unplug it....
1986 930 RUF equipped
Old 02-21-2009, 03:05 PM
It's out. Whew. Thanks a bunch guys. I think the shift rod looks okay . . . . I think.
Old 02-21-2009, 03:22 PM
UNDER CONSTRUCTION!
rick
congrates on the removal
but when we say disconnect coupler we ment that you remove set screw and slide coupler off of tranny shaft.
i think this may have given you that little bit extra space you needed.
cheers ed
Old 02-21-2009, 03:59 PM
1980 911 SC
Houston, the eagle has landed.
Life's a Beach
Old 02-21-2009, 04:56 PM
cl8ton's Avatar
It's out? I thought the OP was why the engine would not fit back into the bay
Guess I gotta read the posts to figger out how this turn of events happened
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 02-21-2009, 07:55 PM
Almost Banned Once
sc_rufctr's Avatar
Hate to be a smarty pants but I built this jack from scratch with one purpose in mind.
The lifting mechanism is made from and old scissor jack screw and block.
Our sponsor sells adaptor plates for hydrologic jacks that seem well designed but I built mine about 8 years ago
The hardest part of the job is getting the car high enough to get the engine down and out.
Old 02-21-2009, 08:07 PM
efhughes3's Avatar
rick
cheers ed
That's exactly right. It sounds like the set screw was loosened, but the coupler was still on the shaft. That is most definitely NOT disconnected.
Next time you do this, print out a checklist of to-do items, and diligently check it off. Even after doing this several times, one can forget a key step.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-21-2009, 08:41 PM
kristan's Avatar
Hi Rick
here is what I think you should do after connecting the engine and tranny:
- push the shift rod in
- put the engine on the ATV stand
- put your small jack under the transmission mounts (with a block)
- once the engine is in the bay, lower the rear of the car
- start wiggling
Oh and don't let you cv joints sit on their bearings, you should
suspend them.
Just my $ .02
Christian
Old 02-21-2009, 10:49 PM
Quick Update
Through everyone's help, I've made some good progress.
Engine and tranny are under the car and the mating process has begun
(1) Engine and tranny are bolted together, and all wiring (stater/rear lights) are hooked up and ready to go.
(2) Rolled the engine/tranny back under the car and mated the shift rod to the coupler.
(3) When trying to attach my sway bar, the old bushings disintegrated. I will have to get new ones (looks like I'm pretty close to being a stockholder with Pelican )
(4) Both CVs are connected, just need to finish up torquing them.
Since I've more or less solved the issues I've raised in this thread, I think I'll post further updates on the original thread I started to track this engine conversion.
2.7L to 3.0L Engine Conversion / Swap
Thanks again. Wouldn't have made it through without all your collective help. I'll try to include what lessons I learned here for any other future souls who should need the advice I needed.
Old 02-23-2009, 12:00 PM
Goldfinger
Mattcamp's Avatar
I hope it's not too late to steam clean the tranny!!! (please no Boy George jokes...)
nice pic in the engine comartment.....I hope to add mine soon.
1984-Carrera (pewter metallic)
Old 02-23-2009, 04:10 PM
