Sway bar question please.....
I have a 1967 912 with no sway bars.From what cars can I mount their systems on to mine(besides the obvious).Thanks for any help
that you can provide. |
Up ya Go!
------------------ 1967 912 "in progress" |
Senior Member
Hello
The period 911 parts do fit. Depending on your body you have maybe to drill holes for the front bar and weld on the support brace for the rear torsion bars. If you allready have the new frontaxle setup you can go for 74-89 front setup. Some aftermarked systems have clamp on parts for the torsion tube. Generally said it is better to invest in good shocks and replacment from the worn parts. Sway bars will not help very much in the handling issue. It just feel different due to flatter cornering. Grüsse |
Thread Tools | |
Rate This Thread | |
