Almost Banned Once
sc_rufctr's Avatar
MSD Ignition help
Hi All
I have a MSD 6AL ignition in my car and was wondering if I could use the stock ignition wires (spark plug leads) with it. I checked Wayne's book but it's unclear about this.
I have a custom set of MSD super conductor wires on the car at the moment but I'm not completely happy with their fit and operation. I'm considering going to a Magnacore set (from our host) but I would rather use the stock ones as I never had a problem with them. (so why did I go MSD? )
Anyways... Fiddle as I must.... Please give me some feedback about your own experiences. Is anybody running the MSD ignition with the stock wires?
Some notes: According to MSD you should not use solid core wires with their ignitions.
I know the stock wires I have are solid core (with resistance built in at either end)... Do these resistors make it possible to use these wires with an MSD?
Wayne: If you have time, Please clarify. Thanks in advance! (I know you're busy)
Old 02-24-2009, 04:33 PM
you see Arthur...
jasonlee's Avatar
I would run the Magnacores. I use them and have no issue. I am not 100% sure about an MSD with stock wires, but IIRC they won't work. I could be wrong, it has been know to happen
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-24-2009, 05:14 PM
<insert witty title here>
Christien's Avatar
Also not sure about stock wires, but I can tell you I have Clewitts and an MSD 6AL and mine works fine.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 02-24-2009, 07:15 PM
Stock wires do not work properly with MSD, -- my experience. Also MSD instructions suggest 8.5 mm wires.
Old 02-25-2009, 11:48 AM
vash's Avatar
i am running the 6AL with the stock, non steel braided wires. no issues.
poof! gone
Old 02-25-2009, 12:13 PM
Almost Banned Once
sc_rufctr's Avatar
MSD rotor mod
Up for a new question...
I've hear about the MSD rotor mod and I want to do this to mine.
I have a pretty clear idea of what to do.
Cut out the resistor in the rotor with a Dremel,
Bridge the rotor tip with the contact centre with a piece of copper,
Soldered in place and seal with some high strength epoxy.
Does anybody have any pics of this mod for interest and ideas?
- Peter
Old 05-01-2009, 09:46 PM
shbop's Avatar
MSD Rotor Modification
This might help.
Jon
Old 05-01-2009, 10:00 PM
Almost Banned Once
sc_rufctr's Avatar
This might help.
Thanks Jon
I've seen this thread but it doesn't show any pics of the actual mod.
But it does descried the mod which has been helpful...
- Peter
Old 05-01-2009, 10:17 PM
