Almost Banned Once
MSD Ignition help
Hi All
I have a MSD 6AL ignition in my car and was wondering if I could use the stock ignition wires (spark plug leads) with it. I checked Wayne's book but it's unclear about this. I have a custom set of MSD super conductor wires on the car at the moment but I'm not completely happy with their fit and operation. I'm considering going to a Magnacore set (from our host) but I would rather use the stock ones as I never had a problem with them. (so why did I go MSD? )Anyways... Fiddle as I must.... Please give me some feedback about your own experiences. Is anybody running the MSD ignition with the stock wires? Some notes: According to MSD you should not use solid core wires with their ignitions. I know the stock wires I have are solid core (with resistance built in at either end)... Do these resistors make it possible to use these wires with an MSD? Wayne: If you have time, Please clarify. Thanks in advance! (I know you're busy) ![]()
you see Arthur...
I would run the Magnacores. I use them and have no issue. I am not 100% sure about an MSD with stock wires, but IIRC they won't work. I could be wrong, it has been know to happen
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
<insert witty title here>
Also not sure about stock wires, but I can tell you I have Clewitts and an MSD 6AL and mine works fine.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Stock wires do not work properly with MSD, -- my experience. Also MSD instructions suggest 8.5 mm wires.
i am running the 6AL with the stock, non steel braided wires. no issues.
poof! gone |
Almost Banned Once
MSD rotor mod
Up for a new question...
I've hear about the MSD rotor mod and I want to do this to mine. I have a pretty clear idea of what to do. Cut out the resistor in the rotor with a Dremel, Bridge the rotor tip with the contact centre with a piece of copper, Soldered in place and seal with some high strength epoxy. Does anybody have any pics of this mod for interest and ideas?
- Peter |
MSD Rotor Modification
This might help.
Jon |
Almost Banned Once
I've seen this thread but it doesn't show any pics of the actual mod. But it does descried the mod which has been helpful...
- Peter |
